beamthegreat
- 116
- 7
Hi! I am going to be as brief as possible in this question.
Im currently trying to design a portable breaker testing device that has a very simple mechanism. Basically, this device must be very small and should be able to fit into something like this:http://goo.gl/BuZ6U
When I insert this device the amperage would probably shoot up to around 400-500 amps albeit for a split second before the breaker trips. However, this is probably enough to melt copper and maybe even iron.
I want to known what type of switch i have to use to withstand the extraordinarily high current caused by an intentionally short circuit. I am going to install a rc delay module into this device as well so that when i press the switch it will cause a 2-3 second delay before the solenoid/relay activates. So what switch/relay should I use?
Additionally, what types of wires should I use? A copper wire surely would not be strong enough to withstand such high temperatures and pressure cause by a short circuit. What materials should I use instead?
Also, what substance should I use to coat the area around the wires to prevent the case from melting?
I willing to speed a maximum of 500 dollars which should be more than enough to purchase some rare/expensive materials suitable for my purpose since I will using a very small amount of it.
I estimate that the temperature would probably heat up to around 500-700 Celsius for a fraction of a second when in use.
Thanks.
Thanks.
