Proving Subset Equality in Vector Spaces: S1∩S2 ⊆ S1 ∧ S2
  • Thread starter Thread starter kNYsJakE
    Proof Span
kNYsJakE
The Problem:
Let S_{1} and S_{2} be subsets of a vector space V. Prove that span\left(S_{1}\cap S_{2}\right)\subseteq span\left(S_{1}\right)\cap span\left(S_{2}\right).
Give an example in which span\left(S_{1}\cap S_{2}\right) and span\left(S_{1}\right)\cap span\left(S_{2}\right) are equal and one in which they are unequal.
Solution:
I could do the proof, so that is not a problem. I found an example when they are equal to each other, but I can't think of an example that those two are not equal. It'd be nice if you could explain it in general case, but it is okay if you just give me an example. Please help me on this!
kNYsJakE said:
The Problem:
Let S_1 and S_2 be subsets of a vector space V. Prove that span(S_1\bigcapS_2)\subseteqSpan(S_1)\bigcapSpan(S_2). Give an example in which span(S_1\bigcapS_2) and span(S_1)\bigcapspan(S_2) are equal and one in which the are unequal.
Solution:
Can you find two sets S_1, S_2 so that their intersection is empty, but they each span the whole space V ?
By the way, doesn't S_1\cap S_2 look better than S_1\bigcapS_2 ?
kNYsJakE said:
The Problem:
Let S_{1} and S_{2} be subsets of a vector space V. Prove that span\left(S_{1}\bigcap S_{2}\right)\subseteq span\left(S_{1}\right)\bigcap span\left(S_{2}\right).
Give an example in which span\left(S_{1}\bigcap S_{2}\right) and span\left(S_{1}\right)\bigcap span\left(S_{2}\right) are equal and one in which they are unequal.
Solution:
test
kNYsJakE said:
The Problem:
Solution:
fixed
Yes. so that means span\left(S_1\cap S_2) equal to a zero set \left\{0\right\}?
And since both span(s_1) and span(s_2) are subspaces of V, they both have a zero set as well, so span(s_1)\cap span(s_2) also should be a zero set. That meas they are equal. I didn't get your answer... Sorry
Linear Algebra. spans!
The Problem:
Nothing.
Solution:
Find S_1 and S_2 so that S_1 \cap S_2 = \emptyset, \text{span}(S_1) = V and \text{span}(S_2) = V .
Take V=R, S_1={1}, S_2={2}. Then S_1 n S_2 is empty, so span(S_1 n S_2)=0. And span(S_1)=R=span(S_2) so span(S_1) n span(S_2)=R.
More generally, let S_1={v_1,...,v_k} be a basis for a subspace W of V and let S_2={u_1,...,u_k} be another basis for that subspace such that {v_1,...,v_k} n {u_1,...,u_k} is empty (for instance, u_i=2v_i). Then span(S_1 n S_2)=0, while span(S_1) n span(S_2)=W.
The idea behind the example is of course that given a subspace, there are many distinct basis for it.
Yeah. That's what i meant.
Well, thanks.
Thank you! =)
I suggest that you consider subsets S1 and S2 of \mathbb R^3 that each contain exactly two vectors.
Don't post the same question in two forums.
I have merged the other thread with this one.
