Find the Angle of a Sliding Solid on a Ball: Step-by-Step Guide
  • Thread starter mohlam12
  • Tags
    Mechanics
In summary: I'll use "N" for now)The centripetal acceleration acts toward the center, and the radial component of the weight is:mg \sin \alpha
mohlam12
154
okay here is the scenario
you have a ball (radius R) and above that ball, there is a solid S that has a mass M and it is on a point A of the ball. You slightly push that solid and it slides around the ball then it leaves the ball at an angle ALPHA. you have to find that angle.
You only have that g=9.81m/ss and that s all.
here is a little drawing...
Please i really need it as soon as possible. thanks
Show us what you've done so far and where you are stuck.
okay
well i used the theorem where you have all the forces equal to the vector of acceleration by the mass... you have the two forces P, and R which is the force coming from the surface of the ball. when the solid leaves the ball, R is equal to zero... but I didnt get to anything.
I used the conservation of mechanic energy in two points, A and B (where the solid quits the ball) I didnt get to anything neither.
if you can just give me hints of what to use or where to start.. thank you
mohlam12 said:
okay
If you are attempting to apply Newton's 2nd law, then you are on the right track. What forces act on the mass at any given distance (or angle) from the top? Hint: How is the mass accelerating?
Conservation of energy is also important for this problem. What's the kinetic energy of the mass after it reaches a given angle?
Newton's 2nd law and conservation of energy are the two things you need to solve this problem. Keep going!
Well, think of the following:
Why is the point mass able to follow the curved surface in the first place?
EDIT:
Dear, oh dear, too late..:frown:
There is the weight P and the surface of the ball R. What makes the mass accelerating is that one force is bigger than the other. The force P changes when the angle change because it equals mgsinALPHA... and the R, I don't know.
When it reaches a give angle, the kinetic energy is equal to 0.5mv² that doesn't have anything to do with a given angle...
What sort of acceleration must an object have if its trajectory is curved?
When we project the two forces on Frenet plot we get
R - mg cos(alpha) = m(v²/radius)
mg sin (alpha) = ma
don't really know what to do next, i have no a, nor the radius, nor R nor anything...
Draw a diagram of the mass when it's at some angle alpha. Show the forces acting on it--both radially and tangentially. What can you say about the acceleration as it slides along the surface? Hint: Pay particular attention to the radial direction.
The kinetic energy equals 0.5mv^2 at any angle--by definition. You need to find the kinetic energy as a function of alpha. Use conservation of energy.
Okay.. I found using the conservation of energy that the kinetic energy is equals to 0.5r(R- gcos(alpha)/m)
I also found that
g(1-sin alpha)=0.5 R/m - gcos alpha
EDIT
for the radial forces, there is : R-mgcos alpha = mv²/r
Please I am Lost Help !
It s midnight and my head hurts SO bad and i ve been working on it since 3 hours and i refuse to go to bed til i find the answer. would someone just start it to me ! I REALLY need to solve it!
OK... finally i came out to
(cos alpha)/2 - sin alpha = R/2gm - 1
I also found that
Well... the change in potential energy is:
[tex]mg\Delta h[/tex]
So the kinetic energy must equal:
[tex]mgR(1 - \sin\alpha)[/tex]
(where R means radius)
EDIT
Almost. Realize that the centripetal acceleration acts toward the center, and that the radial component of the weight is:
[tex]mg \sin \alpha[/tex]
(Use a different letter than "R" to represent the normal force, otherwise you'll confuse it with the radius.)
Don't stop now.
Got it...
Thanks everyone
1. What is the definition of mechanics?
Mechanics is a branch of physics that deals with the behavior of physical bodies under the action of forces. It is concerned with the study of motion, forces, energy, and the interactions between objects.
2. Can you provide some examples of mechanical systems?
Some examples of mechanical systems include a pendulum, a car engine, a bicycle, a seesaw, and a catapult.
3. What are the different types of mechanics?
There are three main types of mechanics: classical mechanics, quantum mechanics, and statistical mechanics. Classical mechanics describes the motion of macroscopic objects, while quantum mechanics deals with the behavior of particles on a microscopic scale. Statistical mechanics studies the collective behavior of large systems of particles.
4. How is mechanics applied in real-world situations?
Mechanics is used in various real-world situations, such as designing and building structures, machines, and vehicles. It is also applied in fields such as aerospace engineering, robotics, and biomechanics.
5. What are some common problems that mechanics can help solve?
Mechanics can help solve problems related to motion, such as calculating the trajectory of a projectile or determining the forces acting on an object. It can also be used to analyze the stability and strength of structures, predict the behavior of machines, and optimize the performance of various systems.
9K
