Fortran Please, Help with Data Reading in Fortran
The discussion revolves around an issue with reading data in Fortran, specifically related to an array declaration and an error message encountered during execution. The user is attempting to read data into a complex array declared as data(1:Nm, 1:Nm, -nw:nw, 0:nwu), but receives an error indicating that the fourth subscript has a value greater than its upper bound of 0. The confusion stems from the variable "nwu," which was initially referred to as "nw-u," leading to misinterpretation of the array's bounds. Participants emphasize the importance of clarity in variable declarations and suggest that the user provide explicit declarations for both the array and the variable "nwu" to resolve the issue. The discussion highlights the need for precise syntax in Fortran, as compilers are strict about variable names and array bounds.
komp
I have been trying to read in a data using Fortran but for some reasons, it doesn't read the data correctly. Please, any help will be appreciated. To read the data, I used the following (Note, for the attached data, Nm=1, nw-nu=5, nw=10).
The array data(i,j,m,n) is declared as data(1:Nm,1:Nm,-nw:nw,0:nw-u). When it tries reading, it spits the error message "Subscript #4 of the array data has value 1 which is greater than the upper bound of 0". A snippet of the code is below.
2015 read(40,"(a72)") lineda
do n=0,nu
do m=-nw,nw-nu
do i=1,Nm
do j=1,Nm
if(index(lineda(1:72),'data') /= 0 ) then
read(40,"(1x,i2,1x,i2,2x,i5,2x,i5,1x,2(1x,e15.8))",IOSTAT=istat) i1,i2,i3,i4,r1,r2
data(i,j,m,n)=dcmplx(r1,r2)
write(809,"(1x,i2,1x,i2,2x,i5,2x,i5,1x,2(1x,e15.8))") i,j,m,n,data(i,j,m,n)
if(istat /= 0) goto 2018
else
goto 2015
endif
2018 continue
enddo
enddo
enddo
enddo
The sample data is attached.
Thank you very much for your help.
Technology news on Phys.org
You don't show the actual array declaration, so I'll have to take your word that it is declared as you say above. The fourth dimension of array has indexes that range betwee 0 and nw - u.
What is u? You don't mention it above. Was this a typo and it should be nu?
do n=0,nu
do m=-nw,nw-nu
do i=1,Nm
do j=1,Nm
else
goto 2015
endif
2018 continue
enddo
enddo
enddo
enddo
Thank you very much for your assistant.
Sorry as I wasn't explicit enough. The array is declared as:
complex*16:: data(1:Nm,1:Nm,-nw:nw,0:nwu)
And for clarity, nw-u is actually nwu and not a subtraction as it seem to show.
That's not what you wrote in post #1, which I have copied below.
So if it's actually nwu, what is the value of nwu?
Your error message shows that there is a problem with subscript 4 of your array.
It is the same. I just explained that nw-u is actually nwu and not subtraction as it seem to show. Yes, it shows that the error is in the 4th argument but I don't know why it should be out of bound when I clearly defined it.
Thanks.
Compilers are totally literal beasts.
You may have written "nwu" in your declaration, but somehow, the compiler is reading and trying to figure out what to do with "nw-u", since that is what you copied from your source file.
Without any other reference for us to look at, how are we supposed to help you solve this problem?
komp said:
It is the same.
NO! nw-u and nwu are completely different!
You wrote nw-u in your post (which I quoted verbatim), but you didn't include the part of your code where you actually declared your array (named data).
Show us
  1. The declaration of your array
  2. The declaration of nwu
