Please show that Hom(Zn,Zn)=Zn.
  • Thread starter Thread starter seventson
seventson
Please show that Hom(Z/nZ,Z/nZ) isomorphic to Z/nZ.
Thanks..
Well, what are your thoughts on the problem?
Build a h: Hom(Z/nZ,Z/nZ) --> Z/nZ homomorphism determined by h(f)=f(1). Is it true?
Go from here and check whether it is well defined (i.e. actually a homomorphism), whether it is in fact injective and surjective (sometimes called one-to-one and onto) then determine whether the inverse is also a homomorphism.
Actually, it is not necessary to check that the homomorphism is injective or surjective: he's asking for Hom(Z/nZ,Z/nZ), not Aut(Z/nZ), so the maps need not be isomorphisms.
He needs to check that house map from hom to Zn is injective and surjective
Exactly the map h mentioned above does actually need to be an isomorphism thus injective and surjective. Also the inverse map needs to be a homomorphism.
The elements of Hom(Z/nZ, Z/nZ) do not need to be isomorphisms.
The trick here is of course to see that homomorphism are uniquely defined by their image of 1 To show this you need to use the fact that they are homomorphisms
Oops, I didn't read carefully enough! Yes, the map h:Hom(Z/nZ,Z/nZ)--->Z/nZ must be an isomorphism; I was thinking of the elements of Hom(Z/nZ,Z/nZ), which of course don't have to be isomorphisms.
Yes the elements of hom don't need to be isomorphism just being homomorphism is enough. And i think i found proof.
