Plotting Derivatives: x''(t) & x'(t) 0-3
jayeffarr
The problem statement.
Suppose x''(t) = 1 for 1\leq(t)\leq2, and x''(t) = 0 for all other (t)
(a) Plot x''(t) for 0\leq(t)\leq3
(b) Plot x'(t) for 0\leq(t)\leq3. Assume x'(0) = 0
(c) Plot x(t) for 0\leq(t)\leq3. Assume x(0) = 0The attempt at a solution
I assumed 'x' being the vertical axis and 't' being the horizontal axis.
For (a) I know that there are going to be two points at 1 and two points at 0.
My main question is when I graph these plots should I treat points 0 and 3 on the t-axis as discontinuities, and just put a point of where they're at and not include them when connecting the non-zero points, or should I connect all the points together, despite the discontinuity?
Hi jayeffarr! :smile:
(have a ≤ :wink:)
jayeffarr said:
… when I graph these plots should I treat points 0 and 3 on the t-axis as discontinuities, and just put a point of where they're at and not include them when connecting the non-zero points, or should I connect all the points together, despite the discontinuity?
Personally, I'd leave them disconnected …
x''(t) has only one value for each t, so why pretend it has more? :wink:
Would you say to do the same thing when it comes to plotting x' and x...
Since x'(t) = t
and the plot will be (0,0), (1,1), (2,2), (3,0).
And x(t) = (1/2)t²
and the plot will be (0,0), (1,0.5), (2,2), (3,0).
...and just draw a line between 1 & 2, while having solid circles and 1 & 3?
Or are you saying just to plot the points without connecting ANY of them?
Not following you :redface:
x'(t) is the area under the graph of x''(t).​
I don't know what you mean by "two points". The graph is the horizontal straight line at y= 1 between 1 and 2, the horizontal straight line at y= 0, the x-axis, for all other t.
"at 3 on the t-xis"? x"(3)= 0 and is 0 for every point near t= 3. Did you mean t= 2? In any case, it really doesn't matter. Technically, the vertical line is not part of the graph but if you can notice that this forms a rectangle under the graph, that will help.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
