How will the change in wavelength affect diffraction in television signals?
  • Thread starter Thread starter poison_ivy
    Diffraction
poison_ivy
I know I'm just a newbie, but i need your help guyz :blushing:
This is a matter of life and death Thanks!
--> In conventional television, signals are broadcast from towers to
home receivers. Even when a receiver is not in direct view of a tower because of a hill or building, it can still intercept a signal if the signal diffracts enough around the obstacle, into the obstacle's “shadow region”. Current television signals have a wavelength of about 50cm, but future digital television signals that are to be transmitted from towers will have a wavelength of about 10mm. (a) Will this change in wavelength increase or decrease the diffraction of signals into the shadow regions of obstacles? Justify your answer with physics. Now, assume that a signal passes through an opening of 5.0m width between too adjacent buildings. What is the angular spread of the central diffraction maximum (ie how large of an angle does the central maximum occupy) for wavelengths of (b) 50cm, (c) 10mm?
To begin, tell us what you know about diffraction.
AM
Diffraction is the spreading of waves around obstacles or squeezing through a small hole. It occurs with sound waves, light, atoms, and subatomic particles. Its like if light waves from 2 slits can interfere
with each other, the light from different parts of the same slit also interfere.
I'm really not good in Physics, i already answered 2/4 of my homework but i can't do this and the other one. I really need help coz this is 15% of my total grade, and this is due tomorrow. Thanks...
For question (a), you need only ask yourself "when is the effect of diffraction most noticeable?" (Think in terms of wavelength). For questions (b) and (c) you will need a formulae. What formulae do you know which can describe the diffraction pattern of a single slit?
Oh ok, i already passed my HW this morning. So, thanks anyway ;)
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
