Pointwise Limits and Uniform Convergence Help
BlackTiger
Hi all
Came across this question which i have attempted to answer but am sure i have gone wrong somewhere, any help would be appreciated...
Suppose fn(x):R-->R, where fn(x)=x+(1/n) (n belongs to N). Find the pointwise limits of the sequences (fn), (1/n fn) and (fn2). In each case determine whether the convergence is uniform.
Now i managed to get all three as being uniformly convergent and am sure i went wrong somewhere. I am still struggling to understand uniform convergence completely. The pointwise limits i computed were x, 0, x2 respectively...sorry i havnt put my working up struggling to use latex.
Your limits are right. (Let f be the limit of f_n). The first sequence is uniformly convergent: given \epsilon >0, choose N to be the lowest integer that is greater than:\frac{1}{\epsilon}.
Then, for all n>N:
|f-f_n|=|x-(x+\frac{1}{n})|=\frac{1}{n}<\frac{1}{N}<\epsilon.
For the second one, note that sup_x|f_n| does not go to 0. This tells you it is not uniformly convergent. To prove this, suppose we are given \epsilon >0. For any choice of N, let x>\epsilon .N-\frac{1}{N}.
Then:
|f-f_N|=|0-\frac{x}{N}-\frac{1}{N^2}|=|\frac{x}{N}+\frac{1}{N^2}|>\frac{\epsilon .N-\frac{1}{N}}{N}+\frac{1}{N^2}=\epsilon.
The third one is very similar. I'm afraid all this might be a bit bewildering if you don't yet understand uniform convergence though! Keep thinking about it and eventually it will click.
PS - I may have made some mistakes here as I did it very quickly, so be sure to check everything!
