Polar Graphs and a question about their poles
  • Context: MHB
  • Thread starter Thread starter m3dicat3d
    Graphs Polar Poles
The discussion revolves around understanding polar graphs, specifically focusing on determining the poles, maximum, and minimum values of radial coordinates for limacons and cardioids. Participants explore how to evaluate these values based on the characteristics of the polar equations.
  • Homework-related
  • One participant suggests that a limacon without an inner loop has a single pole, questioning whether both the maximum and minimum values from the pole would be the same.
  • Another participant clarifies that the pole is the origin and that the maximum and minimum values refer to the maximum and minimum values of r for the given function.
  • A participant explains that for cosine functions, maximum and minimum values occur at 0 radians and π radians, while for sine functions, they occur at π/2 and 3π/2.
  • One participant provides specific maximum and minimum values for a given polar equation, stating the max is 5 and the min is 1, but later corrects a typo regarding the minimum value.
  • Another participant raises a question about whether the presence of loops in limacons affects the determination of maximum and minimum values.
Participants generally agree on the definitions and methods for finding maximum and minimum values in polar graphs, but there are points of clarification and correction regarding specific values and the implications of loops in limacons.
There are unresolved questions regarding the impact of loops on the determination of maximum and minimum values, as well as some confusion about specific values related to different polar equations.
m3dicat3d
Trying to help someone out with their assignments on basic polar graphs. This first question is very easy to determine the poles from as the limacon has an inner loop.
But when you have a limacon WITHOUT (below) an inner loop, how does the "max from pole" and "min from pole" figure? It's been years since I've done this, but my gut is saying it has simply one pole, and the "max" and "min" are the same. For example:
So in the case of the above problem, wouldn't bot "max" and "min be 4?
And if this is case, would you handle a cardioid the same way, for instance:
Would this have both "max" and "min" as 2?
Thanks again :)
Mathematics news on Phys.org
Hi m3dicat3d! :)
The pole is simply the origin.
See for instance wiki about the Polar coordinate system:
The fixed point (analogous to the origin of a Cartesian system) is called the pole, and the ray from the pole in the fixed direction is the polar axis. The distance from the pole is called the radial coordinate or radius, and the angle is the angular coordinate, polar angle, or azimuth.
The max from pole and min from pole are the maximum and minimum values for r.
Thanks so much!
Let me try to clarify here so I'm not explaining this to the person I'm trying to help incorrectly.
Since the pole is analogous to the origin of a Cartesian system, we are finding the max and min values of r from the pole for the given function. In the case of a cosine function, considering that cosine has its max and min values at 0 radians and pi radians respectively, we would evaluate any of the three given equations at 0 and pi to determine max and min for cosine polar graphs.
Similarly, for sine polar graphs, we would evaluate max and mins at pi/2 and 3pi/2.
View attachment 835View attachment 833View attachment 834
So for the polar equation given above, the max at 0pi is 5 and the min at pi is 1.View attachment 836View attachment 837View attachment 838
Likewise our max is 3 and min is 1 here...
View attachment 842View attachment 840View attachment 841
And for the above Cardiod, the max is 2 (evaluated at pi/2) and the min is 0 (evaluated at 3pi/2)Am I understanding this better now?
P.S. Sorry about the attached thumbnail below, don't know how I managed that :p
Hello m3dicat3d,
you got a typo there :) it should be min is $$-1$$:)
edit: Should you not answer if it is a loop or no loop and $$\frac{\pi}{2}$$ intercept as well?
Regards,
$$|\pi\rangle$$
Thanks Petrus!
Sounds as if I'm on the right track here. Yes, the intercept and loop questions we are working through, I just didn't include them here as I understand what we needed to do with those, and just focused on what I was unsure of.
View attachment 843View attachment 844View attachment 845
As far as the min @ -1 typo, were you referring to the no loop limacon above? If you meant the cardioid then I may be missing something else. Thanks :)
  • · Replies 40 ·
  • · Replies 25 ·
