How Do Polaroid Filters Affect Light Perception?
  • Thread starter Thread starter ziad123
    Filters Polaroid
ziad123
A light source is viewed through 2 polaroid filters, A and B (B is infront of A)
a) describe carefully what is seen when polaroid B is rotated slowly in its own plane through 180 degrees.
b) describe how you would use one of the polaroid filters to determine whether the light from the source is polarised or not.
Hello,
There are some equations you could use that would help you figure this out, but its more of a conceptual question that can be figured out without them.
First, you have to ask yourself what happens when light passes through a polaroid filter-- how is the light on your side of the filter different than the light that entered the filter?
If you have two pair of polarized sunglasses, you should take them outside and see for yourself :-)
thanks but sorry ... it doesn't answer my questions lol
I know it doesn't, I'm not going to do your homework for you. If you want some help here, you're going to have to show some effort. What have you done to try to answer these questions?
You can read a description of polaroid material, and what it does, here:
http://230nsc1.phy-astr.gsu.edu/hbase/phyopt/polabs.html#c3"
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
