Position of Particle in Special Relativity (A vs B)
In summary: In this case, x' = f(t') does indeed give the desired velocity in terms of coordinate time.In summary, the position of a particle moving with respect to B is given by ##x′=f(t′)=3t′##. The function of position ##x=f(t)## is just 3 t' in the classical units.
adosar
Recently I have come into Special Relativity and specifically Lorentz transformation. Let's assume two frames A and B moving relative with speed ##v##. The position of a particle moving with respect to B is given by ##x′=f(t′)=3t′##. What is the function of position ##x=f(t)## of the particle for the observer A? Thanks in advance. As I said before I am new to Special Relativity.
What units are you using? In the natural units of relativity, where ##c = 1##, the worldline ##x' = 3 t'## is impossible; it would mean that the particle would be moving at 3 times the speed of light.
Thanks for the reply. I am using the "classical" units where c=3*10^8 m/s. I was just trying to figure out if given a position function for one (A) reference frame we can deduce another position function for another reference frame (B) moving relative with A.
So that means ##x' = 3 t'## implies a speed in the primed frame of 3 m/s? Ok, good.
Yes, we can, but for the simple function you give, you don't need the full Lorentz transformation to figure it out. You just need the velocity addition law: in the unprimed frame, the function will be ##x = w t## where
w = \frac{v + 3}{1 + \frac{3 v}{c^2}}
Likes adosar
This is just straight algebra. You have ##x’=f(t’)## so just substitute ##x’=\gamma\ (x-vt)## and ##t’=\gamma\ (t-vx/c^2)##. Then solve for ##x=g(t)##
Likes adosar
Thanks so much. I was trying to figure it out through position and time transformations.
That's how you derive the velocity transformation, so it ought to have worked.
Just a comment. The transformation of x' = f(t') into x = f(t) winds up to be rather ugly. t and t' are different coordinates, due to the relativity. Thus, as other posters have mentioned, one needs to transform both x' and t'. The transformation x' = f(##\tau##) into x = f(##\tau##) is much simpler. Here ##\tau## denotes proper time. Because ##\tau## is a world scalar, it doesn't need to be transformed, thus one only needs to use the Lorentz transform to transform x' to x, making it a significantly easier calculation.
Sometimes you do want to express things in terms of coordinate time t rather than proper time ##\tau##, but it's often worth looking at the alternative.
Likes Dale and Nugatory
1. What is the difference between a particle's position in special relativity compared to classical mechanics?
In classical mechanics, a particle's position is described by its coordinates in three-dimensional space. However, in special relativity, the position of a particle is described by its coordinates in four-dimensional spacetime, which includes time as the fourth dimension.
2. How does the position of a particle change in special relativity when it approaches the speed of light?
In special relativity, as a particle approaches the speed of light, its position in space appears to contract in the direction of motion. This phenomenon is known as length contraction and is a consequence of the time dilation effect.
3. Can a particle's position in special relativity be measured in the same way as in classical mechanics?
No, the measurement of a particle's position in special relativity requires the use of four-dimensional coordinates and the concept of spacetime. This is different from the traditional three-dimensional coordinates used in classical mechanics.
4. How does the position of a particle in special relativity affect its energy and momentum?
In special relativity, the energy and momentum of a particle are not independent quantities but are related to each other through the famous equation E=mc². This means that as a particle's position changes in spacetime, its energy and momentum will also change accordingly.
5. Is the concept of a fixed position in space and time still applicable in special relativity?
No, in special relativity, the concept of a fixed position in space and time no longer holds. This is because the position of a particle is relative to the observer's frame of reference and can change depending on the observer's relative motion. Therefore, there is no absolute position in spacetime in special relativity.
