Position of Ball w/ Initial Velocity 10 m/s After 2.12794 s
The discussion focuses on calculating the position of a ball after 2.12794 seconds with an initial velocity of 10 m/s under the influence of gravity, which is 9.8 m/s². For a downward throw, the correct formula is y = Vot + 1/2gt², leading to a position calculation that factors in the negative acceleration due to gravity. For an upward throw, participants clarify the need to account for the downward direction of gravity in the calculations, emphasizing the importance of vector direction. The calculations provided by users indicate confusion over the signs and values, leading to incorrect results. Accurate application of the equations is crucial for determining the correct position of the ball.
kimikims
A ball has an initial velocity of 10 m/s.
The acceleration of gravity is 9.8 m/s^2.
What will be it's postion after 2.12794 s if it is throw
a) down with an initial velocity of 10 m/s? Answer in units of m.
b) up with an initial velocity of 10 m/s? Answer in units of m.
I think for b you use:
y = Vot + 1/2gt^2
I got 43.47m, but that's wrong.
I got -1.03, i think your calculations are wrong, and also i forgot if its negative it's pointing down, so it's going down.
use this : y = 10t - 9.8t²/2 and the t is given
the g-vector points downwards the y-axis thus you need to write a minus sign. Watch out when you work with vectors : you have the magnitude of a vector AND the direction of a vector...
marlon
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
