Position of particle in a magnetic field
To determine the position of a charged particle in a magnetic field over time, the Lorentz force equation is applied, resulting in acceleration components Ax and Ay based on the particle's velocity and the magnetic field. The equations for position X(t) and Y(t) are derived, incorporating constants A1, A2, A3, and A4, but the user is uncertain how to proceed from this point. The discussion highlights the need for further guidance on solving the equations for specific time-dependent positions. The focus remains on understanding the motion of the particle under the influence of the magnetic field. Additional insights or methods to solve the equations are requested.
gabrown
I am wanting to get position (x and y) of a particle moving in a magnetic field as a function of time.
So, we have a particle of mass m, charge q, velocity (Vx,0,0) moving in a magnetic field (o,o, Bz) starting at t=0 as (0,0,0), what is X(t) and Y(t).
Lorentz Force F=q(VxB)
F=Ma
Ax = q Vy Bz
Ay = - q Vx Bz
follows that
X(y,t) = (q.Y.Bz + A1)t + A2
Y(x,t) = (-q.X.Bz +A3)t + A4
but not sure where to go from here
cheers
Gareth
No ideas?
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
