How Do You Analyze Acceleration on a Position vs. Time Graph?
The discussion revolves around analyzing acceleration on a position vs. time graph, specifically ranking the acceleration in various regions of the graph. Participants are attempting to understand how to interpret the graph to determine where acceleration is positive, negative, or zero.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants discuss the relationship between the slope of the graph and velocity, and how changes in slope relate to acceleration. There are attempts to identify regions of increasing, decreasing, and constant slope.
Some participants have provided insights into the nature of the graph and the relationship between position, velocity, and acceleration. There are multiple interpretations being explored, particularly regarding the identification of regions where acceleration is positive or negative. Guidance has been offered, but there is no explicit consensus on all points raised.
Participants express confusion regarding the interpretation of the graph and the definitions of velocity and acceleration, particularly in relation to points where the slope is zero or changing. There are references to homework constraints and the urgency of preparing for an upcoming exam.
omc1
A plot of Calvin's Mom's position vs. time is shown. Rank the acceleration of the five regions (e.g., A, B, etc.) from most negative to most positive
See attachment!
I think that b is the most negative and c is zero, a is increasing acceleration but I just don't understand how to read this graph. Please help my final is tomorrow! thanks
See attachment!
This is position vs. time, so the derivative (slope at any point) of this graph gives the velocity.
The rate of change of the velocity is the acceleration.
So, on this graph:
Where is the slope increasing?
Where is the slope decreasing?
Where is the slope constant?​
well, the slope is increasing at a, and maybe at e, its constant at c, and decreasing at d, then at b it is slowing down
Is the slope (not the function itself) really decreasing in D?
The other parts are right.
well at first i thought d was constant and since slope relates to the velocity then a is zero but iam just really confused when trying to read this graph
Your first thought was right. D corresponds to a constant, negative velocity. No acceleration there.
ok that makes sense, thanks!
Bumping an old thread for a little help on a similar question.
I am given a position vs time graph:
I am asked where acceleration is positive and where it is negative.
I believe I understand that when the slope of the line is increasing then the acceleration is positive. When the slope of the line is decreasing then the acceleration should be negative. Correct?
So from what I see here acceleration at the given points should be:
A - Negative
B - 0
C - Negative
D - Positive
E - 0
F - Positive
Yet these answers are being marked as incorrect when I submit them. Can PF lend me a hand here? Thank you!
A - Negative
B - 0
C - Negative
D - Positive
E - 0
F - Positive
I think B and E are incorrect.
Curvature upward acceleration is positive and curvature downward acceleration is negative.
B and E appear to be where the object changes direction. An earlier part of the question asked where velocity was 0 and those were the correct answers. Can you have acceleration without velocity?
Apparently you can, that was the correct answer, thank you!
Well I thought that you were looking for acceleration.
Yo if the graph is position vs time then velocity would be zero when the slope is zero but if they ask for acceleration then its different. (refer back to my original post).
Yep, got it now. I guess I wasn't thinking of local min/max points as a change in slope. Not sure why... Ha. Thank you again!
Yeah no problem! Can you help me on my post? :)
I see that you're new to PF, so Welcome!
I should point out that according to the rules of this forum, you should have started a new thread to post this rather than "highjacking" an existing thread.
13K
9K
