Positively charged side with induced emf
A solid conductor moving at 150 m/s through a 0.045T magnetic field raises questions about which side becomes positively charged and the induced emf. The right-hand rule is suggested as a method to determine the direction of force on the electrons within the conductor. As electrons are pushed to one side by the magnetic field, that side becomes negatively charged, while the opposite side becomes positively charged due to a deficit of electrons. Understanding the Lorentz force law clarifies that the side with fewer electrons is the positively charged side. The discussion concludes with a confirmation that this explanation is helpful in resolving the confusion.
VenaCava
A solid conductor travels at 150 m/s across a uniform .045T magnetic field. Which side is positively charged and what is the emf across this block?
I actually solved for the emf no problem. I am having difficulty determining which side is positively charged. There is a diagram which accompanies the question. It can be found in this pdf file (first question): http://pittmath.com/Physics12/Ultimate%20Induction%20Review%20Assignment.pdf
if you can't open it, the diagram simply shows a rectangular block with a velocity to the left going through a magnetic field going out of the page. The question asks if the positive side of the rectangle is the top or the bottom.
I was told to use the right hand rule, but I'm not clear which one or even what I'm looking for.
If you could help that would be greatly appreciated.
Do you know the Lorentz force law? (force in terms of charge, velocity, and magnetic field) I'd use that to determine the direction of force on the electrons in the metal. Remember that the direction of the cross product of two vectors is given by the right hand rule.
I think you lost me a little bit.
I don't understand what makes a side "positive." That's my main problem.
Well, think about what happens to the electrons in the metal. They are charged particles, moving through a magnetic field (not parallel to the field), so they will feel a force. That force will tend to push them toward one side of the metal bar. Now, since electrons are negatively charged, the side that the electrons are pushed toward will have more electrons than protons, so it will have a slight excess of negative charge. That's the negative side. The opposite side of the bar will be missing some electrons, so it will have a slight excess of positive charge. That's the positive side.
Does that make sense?
thank you that helped a lot.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
