Positron Helix magnetic field, find pitch and radius
The discussion focuses on calculating the pitch and radius of a positron's helical trajectory in a uniform magnetic field of 0.137 T. The positron moves at a speed of 5.40 x 106 m/s, entering the field at an angle of 85.0° with the x-axis. The pitch (p) is determined using the formula p = (vx)T, where vx is the x-component of velocity, and T is the period of motion. The radius (r) is calculated using the equation R = (m(vx))/(qB), where m is the mass of the positron, q is its charge, and B is the magnetic field strength.
  • Understanding of classical mechanics, specifically motion in magnetic fields
  • Familiarity with the equations of motion for charged particles in magnetic fields
  • Knowledge of trigonometric functions, particularly sine and cosine
  • Basic understanding of the concepts of pitch and radius in helical motion
  • Study the derivation of the Lorentz force and its application to charged particles
  • Learn about the motion of charged particles in magnetic fields using simulations
  • Explore the relationship between pitch, radius, and velocity in helical trajectories
  • Investigate the effects of varying magnetic field strengths on particle motion
Students studying electromagnetism, physicists analyzing particle motion, and educators teaching concepts related to charged particles in magnetic fields.
JosephK
A uniform magnetic field of magnitude 0.137 T is directed along the positive x axis. A positron moving at a speed of 5.40 106 m/s enters the field along a direction that makes an angle of θ = 85.0° with the x-axis (see figure below). The motion of the particle is expected to be a helix.
(a) Calculate the pitch p of the trajectory as defined in figure.
(b) Calculate the radius r of the trajectory as defined in figure.
vx = sqrt(vy^2 + vz^2)
R = (m (vx) )/ qB
T = (2 pi r ) / vx
To find vx multiply v vector by sin(5 degrees). Plugging in values to radius. Answer is significantly wrong. To find pitch, p = (vx)T = 2 pi r.
I understand this problem now. Since the magnetic field is directed in the x direction, the magnetic force is not directed in the x direction. Thus, acceleration in the x direction is zero. And so, velocity in the x direction is constant. We obtain velocity in the x direction by multiplying velocity vector by cos 85 degrees. We now find the period. It follows that the period is the circumference of the circle divided by the velocity of the particle. Replacing the velocity by the equation v = qBr/m, the period is equal to ( 2 pi m ) / q B. Consequently, the pitch p is equal to the velocity in the x direction times T.
Now we solve part B. We assume that velocity in the y direction is equal to the velocity in the z direction. Then, velocity in the y direction is equal to the velocity vector times sin 85. Then, by equation, r = (v m) / qB, we find the radius.
  • · Replies 17 ·
