Potential energy of a spring and transverse motion
The discussion revolves around understanding the potential energy of a spring and its behavior during transverse motion. The key equation used is W = 1/2kL^2, where L represents the stretched distance. Participants explore how to parameterize the stretch of the spring as a function of the distance moved, xm, and emphasize the need to relate the height L(x) to the distance x. Confusion arises regarding the assumption that the work done in different scenarios is the same, leading to discussions about deriving the force needed to extend the spring. Ultimately, the solution hinges on correctly determining L(x) to find the force required for the spring's extension.
jskro
L = Stretched distance
L0 = Unstretched distance
W = 1/2kL2
In attempting to help a friend with this problem, having taken this same physics class under a different professor, i was completely stumped by this problem. I know that Fx = kL, but i can't make any headway on figuring out the part of the problem that involves the transverse of the spring that leads to a distance pulled of xm with the same applied force that stretches the spring the same distance. Is there something easy that I'm missing?
For a) you need to parameterise the amount it has stretched in fig b as a function of x. Geometrically think of take the stretched spring in b, and rotating it back to vertical. Then consider the relation between the extrat height L(x) and the distance it was moved x. After this I presume you are okay?
So basically, because the work done in each of the two scenarios is the same?
Fx*xm = 1/2kL^2
xm = (kL^2)/(2Fx)
You do not know that the work done is the same, you just follow the prescribed method to determine it. I'm getting a bit confused by what you mean by
Fx*xm = 1/2kL^2
xm = (kL^2)/(2Fx)
What do you think is the answer to question a), Ie L(x)=? once you know this, then you can consider the force needed to extend the spring by L(x), and that is the answer to question b).
By rotating b back vertically, the distance it was pulled is xm
L(x) = xm
Exactly, so now you can find the magnitude of the force easily enough, the rest follows from this.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
