Is PSI in a Pneumatic Line a Measure of Potential Energy?
PSI in a pneumatic line is not a direct measure of potential energy, as pressure is defined as force per unit area rather than energy itself. While pressure can perform work and may be associated with energy density, it does not equate to potential energy in the same way voltage does. The distinction lies in the units of measurement, where energy incorporates length and force, unlike pressure. Therefore, referring to PSI as potential energy density is inaccurate. Understanding these differences is crucial for accurate discussions about pneumatic systems and energy concepts.
DJM111188
I wasn't sure exactly where I should have posted this but here I go...
I was reading that Voltage is a measure of potential energy. With that same mind frame would it be correct to say that PSI is also a measure of potential energy? Specifically referring to the psi in an pneumatic line for say a tool.
Pressure is not energy, it is force per unit area (pounds per square inch, for example), wheras energy has length*force units (inch-pounds, for example). However, since pressure has the ability to do work, pressure (gas / liquid) may be considered as pressure energy density (energy per unit volume), but Potential Energy density is not the right term here.
Gracias sir.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
