Potential triple integrals
In summary, the conversation is discussing the use of the expression -Gm\rho2\pi\left(R_2^2-R_1^2\right) for the potential of a point-mass "m" inside a spherical shell with radii R_1 and R_2 and density \rho. The speaker has already found the potential outside of a homogeneous sphere with the same density and is now trying to use these results to find the potential inside a homogeneous sphere. They propose considering a point on the inside of the shell and adding the two potential formulas using the correct radii. However, it is mentioned that something may be missing in the given expression for potential.
cscott
782
Does [itex]-Gm\rho2\pi\left(R_2^2-R_1^2\right)[/itex] make sense for the potential of a point-mass "m" inside a spherical shell of radii [itex]R_1< R_2[/itex] and density [itex]\rho[/itex]?
Now I've already found the potential outside of a homogeneous sphere of same density. I'm now asked to use these two results to find the potential inside a homogeneous sphere of again indeity density sphere, using the previous two results.
Can I do this by considering the point on the inside of the shell with a sphere in the space in the middle? Does it make sense to add the two potential formulas using the correct radii?
Expression for potential is GMm/R. So something is missing in the given expression
Yes, it does make sense to use the triple integral formula for calculating the potential inside a spherical shell with a point-mass inside. The equation you have provided, -Gm\rho2\pi\left(R_2^2-R_1^2\right), is the correct formula for calculating the potential inside a spherical shell with a point-mass inside. This can be derived by considering the potential due to the point-mass and the potential due to the spherical shell separately and then adding them together. The radii used in the formula should correspond to the radii of the point-mass and the spherical shell, as you have correctly mentioned.
In order to find the potential inside a homogeneous sphere with the same density, you can use the same approach and add the potential due to the homogeneous sphere and the potential due to the point-mass separately. The resulting formula would be different from the one for a spherical shell, but it would still involve triple integration. This is because the potential due to a homogeneous sphere is not the same as the potential due to a spherical shell.
Therefore, it is possible to use the previous two results to find the potential inside a homogeneous sphere by considering the point on the inside of the shell as a separate point-mass and adding its potential to the potential of the homogeneous sphere. This approach is valid and makes sense from a mathematical perspective. However, it is important to note that this approach assumes that the point-mass is located at the center of the homogeneous sphere. If the point-mass is located at a different position, then the formula for the potential would be different.
1. What is a potential triple integral?
A potential triple integral is a mathematical concept used in multivariable calculus to calculate the volume of a three-dimensional region bounded by three variables. It involves integrating a function of three variables over a three-dimensional region.
2. What is the difference between a triple integral and a potential triple integral?
A triple integral is used to calculate the volume of a three-dimensional region bounded by three variables, while a potential triple integral is specifically used to calculate the volume of a three-dimensional region that has a non-constant rate of change along one or more of the variables. In other words, a potential triple integral takes into account the changing rate of the function over the region being integrated.
3. How is a potential triple integral evaluated?
A potential triple integral is evaluated by using the Fundamental Theorem of Calculus in three dimensions, which states that the integral of a function over a three-dimensional region can be calculated by finding the antiderivative of the function and evaluating it at the boundaries of the region. This is essentially a three-dimensional version of the Fundamental Theorem of Calculus used in single variable calculus.
4. What are some real-life applications of potential triple integrals?
Potential triple integrals have many applications in physics and engineering, particularly in the fields of fluid mechanics, electromagnetism, and heat transfer. They are used to calculate the volume and mass of three-dimensional objects, as well as to determine the flow of fluids and heat through three-dimensional regions.
5. Can potential triple integrals be applied to non-constant functions?
Yes, potential triple integrals can be applied to non-constant functions, as long as the function is continuous and integrable over the region being considered. In fact, potential triple integrals are specifically designed to take into account the changing rate of a function over a three-dimensional region, making them useful for a wide range of applications.
