Calculating Reflection Coefficient for a Potential Well
captainjack2000
A potential well with V(x)=0 for x<0 and V(x) = Vo for x>0. The particle has energy E greater than Vo and is incident from the left side. Calculate the reflection coefficient.
Relfection coefficient is given by R= (B*B)/(A*A)
I think that the time independent Schrodinger equation for the two regions are
x<0 (-hbar/2m)dphisquared/dphi =Ephi(x)
and
x>0 ((-hbar/2m)dphisquared/dphi +Vo phi = Ephi(x)
the solutions to this
x<0 Aexp(ik1x) +Bexp(-ik1x) = phi(x)
x>0 Cexp(ik2x)
is this right
carrying this through and equating two solutions at x=0
A+b = C
and equating differentials at x=0 gives
ik1(A-B) = -ik2C/k1
but when I solve for A and B i get
A=(c/2)(1-ik2/k1)
B=(c/2)(1+ik2/k1)
when I find R i get R=1 which must wrong because particle is not always reflected it should pass over the potential barrier?
Things started to break down when you evaluated the derivatives. Why is there a k1 on the left side? And why didn't the i's cancel out in the final solution?
ik1(A-B) = -ik2C/k1
Apart from the extra k1 on the left side which Dick pointed out, why is there a minus sign on the right side?
sorry should the differentials be (A-B)=-ik2C/k1?
in which case i still get the same solutions for A and B and a coefficient of 1
Why is there a minus sign on the left hand side?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
