Calculating Force of Friction for Constant Velocity - Jay Matheson
  • Thread starter atOnz
In summary: If you start to pick up the book, the F(resultant) force will be greater than the gravity force, thus the book will be moving.In summary, the car is moving if there is a resultant external force acting on it.
atOnz
25
Power/Forces Help~~!
Hey there, first time using this forum. Have a question that I think I worked out correctly but am hoping to make sure I did (assignment).
A car must do 10kW to maintain a constant velocity of 25m/s on flat ground. How large are the frictional forces opposing it's motion?
Velocity = 25m/s
Power = 10 000W
Acceleration = 0 m/s^2
-First I converted kW into W: 10kW x1000W/1kW = 10 000W.
-Then I found the force applied (I think, please clarify):
P = Fv
10 000W = F(25m/s)
400N = F (applied?)
I asked my teacher a little on this question and he hinted at Force of Friction being 400N. But I don't understand why it could be that.
If the force applied and the force of friction are equal, doesn't that mean that the car is not moving? Please explain!
-Jay Matheson
Velocity = 25m/s
Power = 10 000W
P = Fv
10 000W = F(25m/s)
400N = F (applied?)
-Jay Matheson
Hi Jay and welcome to PF,
Your working is absolutly correct. As for the balance forces, can you tell me what is Newton's first law?
~H
Reply
~H
Law of Inertia - An object at rest or in uniform motion will remain at rest or in uniform motion unless acted on by an external force.
So the car will remain moving uniformly unless it is acted on by an external force. Friction being the external force.
F(applied) - F (friction) = 0N (net force)
400N - 400N = 0N (net force)
Then the car is moving uniformly, meaning that it is not at rest? So if there is no force acting on this car since friction and applied forces cancel each other out, then it is moving or not moving?
-Jay
No, that only means there is no acceleration because there is no net force. The question states a "constant velocity of 25 m/s."
Yep, that's correct. I would just like to add the work resultant into your law of inertia for clarification
"An object at rest or in uniform motion will remain at rest or in uniform motion unless acted on by a resultant external force."
Do you understand now?
~H
Reply
Just for curiosity, say that the force applied was greater than the force of friction, would that mean that the car was accelerating?
Yes, by Newton's second law;
[tex]\Sigma \vec{F} = m \vec{a}[/tex]
There would be a resultant force, thus leading a and acceleration which is equal to the resultant force divided by the mass of the car.
~H
~H
It's hard for me to get my head around that an object with no forces acting on it (because they cancel) can still be moving. Wouldn't there have to be a force to keep the car moving?
I think of it like this; If a book is sitting on a desk then F(normal) and force (gravity) are equal, meaning the book is not moving. Same as my situation except different vectors?
EDIT:
So I am still thinking (maybe overthinking? :P) but I have concluded this from what you wonderful people have said to help me:
F(applied) > F(friction) ~ Then there is acceleration.
F(applied) = F(friction) ~ Then there is uniform velocity (possibly at rest??)
F(applied) < F(friction) ~ Then there is no movement and no acceleration.
Cool?
Technically, it means the book it not accelerating. Consider this situation, a hockey player hits a puck across an ice rink. Once the puck is no longer in contact with the stick what are the force(s) acting?
~H
~H
The only forces acting on the puck are F(normal), F(gravity), which cancel each other out. Also the F(friction) is gradually slowing down the puck. So the puck eventually stops. Meaning that the car in my question, which was constantly moving at a velocity of 25m/s will stop, So if the two forces are equal then the car will not stop until the force applied (engine) stops.
Haha I think I get it now! F(applied = F(friction) ~ uniform motion and will stay uniform unless some other force acts on it or the force applied < force of friction.
Yep, you've got it. Just keep in mind net force and you'll have no worries :biggrin:
~H
Thank you very much for your help with this problem and for helping my better understand forces. It's much appreciated. I guess I was too focused on the whole: F(friction) = U(coeffcient of friction) x F(normal).
If I have more questions do I post them in this thread or start a new one?
A new thread, for goodness sake.
Quick question:
In my actual question I am given 10.0kW and 25.0m/s. Would my finally answer of 400N be 4 x 10^2 since I am only given at most 2 sigfigs?
Nope, it would be 400N and it appears to me that you are given three significant figures; 10.0 kW and 25.0 m.s-1. Also, in most cases it is acceptable to quote one more significant figure than was given.
~H
~H
I thought 10.0 had only two significant figures since anything to the right of a non-zero digit is just a palce holder? I see why 25.0 is 3 but if by some chance 10.0 is 2 sig figs I should go with that many sigfigs, correct?
Even if you consider 10.0 to have only two significant figures, you can still go to 3sf in your answer. It is perfectly acceptable to quote your answer to one additional significant figure than was given in the data; unless ofcourse you tutor / question has told you otherwise. For example, [itex]\frac{5}{2} = 2.5 \neq 3[/itex]. Both the intial figures (5 & 2) were given to 1sf, however, the answer is given as 2.5 (2sf) not 3.
Eitherway, this is irrelavent, 10.0 has three significant figures.
Please take a look at this page;
http://en.wikipedia.org/wiki/Significant_digits
~H
Question 1:
What is the formula for calculating force of friction for constant velocity?
The formula for calculating force of friction for constant velocity is Ff = u * N, where Ff is the force of friction, u is the coefficient of friction, and N is the normal force.
Question 2:
What does the coefficient of friction represent in the formula?
The coefficient of friction represents the amount of resistance between two surfaces in contact. It is a dimensionless value that is specific to the two materials in contact.
Question 3:
How is the normal force determined in this calculation?
The normal force is determined by the force of gravity acting on an object. It is equal to the weight of the object and is perpendicular to the surface on which the object is resting.
Question 4:
Can the force of friction for constant velocity be negative?
No, the force of friction for constant velocity can never be negative. It always acts in the opposite direction of motion and therefore will always have a positive value.
Question 5:
What are the units for the force of friction in this calculation?
The units for the force of friction will depend on the units used for the coefficient of friction and the normal force. However, the most common units are Newtons (N) or pounds (lbs).
