Power in the components of an RC circuit as a Function of time
The discussion focuses on analyzing a simple RC circuit with an EMF source, resistor, and capacitor. Key equations for power in the resistor and battery are established, but the main challenge lies in determining the rate of energy stored in the capacitor. Suggestions for solving this include using conservation of energy, finding voltage drops across components, or integrating current to derive charge. The participant concludes that the energy not dissipated by the resistor is stored in the capacitor, affirming the approach to calculate power relationships. Overall, the equations for the resistor and battery are confirmed as correct.
physninj
A simple RC circuit with an EMF source ε, Resistor R and capacitor C are in series. When the switch is closed find the rate of energy stored in the capacitor, the power dissipated in the resistor, and the power supplied by the emf as functions of time.
For the resistor
P=i2R
i=(ε/R)e-t/RCFor the battery
P=iε
i=(ε/R)e-t/RC
For the capacitor
q=CE(1-e-t/RC)
U=q2/(2C)
I feel decent about the expressions I got for the resistor and the battery.
Pres=[(ε/R)e-t/RC]2R
Pbat=[(ε/R)e-t/RC]εThe problem I'm having is getting the energy rate in the capacitor. I tried to just use the energy equation from above and divide by time but I don't think it's right, It's undefined at t=0, and I need to evaluate these equations at that point in later steps.
I think I may need to plug it into the energy and then take the time derivative. Its pretty messy though, is there a better way?
[CE(1-e-t/RC)]2/(2Ct)
Thanks for any input
For the resistor
P=i2R
i=(ε/R)e-t/RC
For the battery
P=iε
i=(ε/R)e-t/RC
For the capacitor
q=CE(1-e-t/RC)
U=q2/(2C)
Pbat=[(ε/R)e-t/RC
There are several ways to find the rate of energy stored in the capacitor.
You can use conservation of energy. You know the power supplied by the battery (rate of work done by the battery). You know the power dissipated in the resistor. From those it's fairly direct to account for the rest of the energy.
Alternatively, you can find the voltage drop across the resistor as a function of time. From that you can find the voltage drop across the capacitor as a function of time. Use that with U = (1/2)V2C.
You can integrate the current to find the charge on the capacitor.
I see, because what's not dissipated by the resistor is stored in the capacitor. I think I will take that route.
So its just
Pemf-Presistor=Pcapacitor
My other equations look alright I'm assuming?Thanks a bunch.
So its just
Thanks a bunch.
Yes.
They look right.
