Calculating Power Requirements for a Ski Lift
  • Thread starter Thread starter elsternj
    Lift Power
To calculate the power required for a ski lift, the initial approach involved converting speed to meters per second and determining the height using trigonometric functions. The total weight of the riders was calculated, and work was computed using the formula W=mgh. However, the time calculation was incorrect, as the distance moved by the rope was misinterpreted; the correct distance is 350 meters, not the height. The final power calculation should use the correct distance and constant speed, leading to a more accurate result. The discussion highlights the importance of correctly interpreting problem statements and verifying calculations for accurate outcomes.
elsternj
A ski tow operates on a slope of angle 14.3 of length 350m . The rope moves at a speed of 12.1km/h and provides power for 49 riders at one time, with an average mass per rider of 75.0kg Estimate the power required. to operate the tow.
W=mgh
P=W/T
x-x0=(V0x+Vx/2)t
First I converted my speed to m/s
12.1km/h = 3.36m/s
Then I had to find the height of this ski lift. I figured the height would be the y component of the ski lift. 350Sin(14.3)=86.45
m = 75*49 = 3675
W=mgh
W=(3675)(9.8)(86.45)=3113496.75
Then I had to find the time.
x-x0=(V0x+Vx/2)t
350=(3.36/2)t
t = 208.3
P = 3113496.75 / 208.3 = 14947.18 (not the right answer)
Where did I go wrong?
You assumed that the the rope and riders were accelerated from rest to 3.36 km/s. Instead, the problem is (somewhat unclearly) stating that the speed is constant at 3.36 km/s.
okay so if the speed is constant then acceleration is 0.
3.36=86.45/t
t=25.73
P=w/t
P=3113496.75/25.73=121006.48 not the right answer
i feel that I am particularly unsure about my W=mgh equation in this problem.
oops
3.36=86.45/t
t=25.73
P=w/t
Your Work done is OK, but your time is incorrect. The rope moves 350 m , not 86.45 meters.
Incidentally, if you can calculate the force in the rope, F, you can use P =Fv as a check on your answer.
ah and there's the right answer! of course it should have been 350! I don't know what made me use the height. Thank you so much for the help! I love this site. I see tutors at my college but it is currently our spring break and we have a test the week we get back! This has been just as helpful as my tutors! Much appreciation to you and everyone else.
