Solve Precalculus Problem: Perimeter & Area of a Pentagon
  • Thread starter Thread starter pasatom20
To find the perimeter and area of a regular pentagon inscribed in a circle with a radius of 9, the problem suggests breaking the pentagon into triangles. Lines should be drawn from the center of the circle to each vertex of the pentagon to determine the angles between these lines. The angle between the lines is essential for calculating the area of the triangles formed. The discussion indicates that the user has made progress in solving the problem with community assistance. Overall, the focus is on using geometric principles to simplify the calculations for the pentagon's dimensions.
pasatom20
HI guys, I'm really confusing about this Q., and I hope you guys can give me some help. :smile:
- Find the perimeter and the area of a regular pentagon inscribed in circle of radius 9.
Break the inscribed pentagon into something simpler, such as triangles.
Draw lines from the center of the circle to the vertices of the pentagon. What is the angle between these lines?
I just figured out how to work on the problem. thanks everyone for helping me.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
