Present this matrix as a multiplication of elementary matrices question
transgalactic
how to present this matrix as a multiplication of elementary matrices
<br /> \bigl(\begin{smallmatrix}<br /> 0 &amp;6 &amp;2 \\ <br /> 1&amp; 1 &amp;0 \\ <br /> 5&amp;3 &amp;1 <br /> \end{smallmatrix}\bigr)<br />
i can't understand in general what are they doing in this solution
http://img144.imageshack.us/img144/9508/34036247.th.gif
I don't know what you mean by "I understand in general". Do you know how to "row-reduce" a matrix? Every "row-operation" corresponds to an elementary matrix: the matrix you get by performing that same row operation on the identity matrix.
There are many different ways to row-reduce any matrix but I like to start on the left and clear one column at a time. For example, I might, as the first step in row-reduction, swap the first two rows, going from
\begin{bmatrix} 0 &amp; 6 &amp; 2 \\ 1 &amp; 1 &amp; 0 \\ 5 &amp; 3 &amp; 1\end{bmatrix}
to
\begin{bmatrix} 1 &amp; 1 &amp; 0 \\ 0 &amp; 6 &amp; 2 \\ 5 &amp; 3 &amp; 1\end{bmatrix}
Which corresponds to the elementary matrix we get by swapping the first two rows in the identity matrix:
\begin{bmatrix} 0 &amp; 1 &amp; 0 \\ 1 &amp; 0 &amp; 0 \\ 0 &amp; 0 &amp; 1\end{bmatrix}
The next thing I might do is subtract 5 times the (new) first row from the third.
\begin{bmatrix} 1 &amp; 1 &amp; 0 \\ 0 &amp; 6 &amp; 2 \\ 0 &amp; -2 &amp; 1\end{bmatrix}
and that corresponds to the elementary matrix
\begin{bmatrix} 1 &amp; 0 &amp; 0 \\ 0 &amp; 1 &amp; 0 \\ -5 &amp; 0 &amp; 1\end{bmatrix}
What we have done so far corresponds to the product of those two elementary matrices. Continue to row-reduce and write down the corresponding elementary matrix. Be careful about the order of multiplication.
so when multiply all the elementary matrices
i get the original one
but they multiply only the first 4??
and i can't understand what's E what F in the equations
There are 6 elementary matrices. I don't see where they are multiplying "only the first 4".
The "E" matrices are the elementary matrices corresponding to the row operations needed to row-reduce matrix A. The "F" matrices are their inverses (which are also elementary matrices). A is the product of the "F" matrices.
i looked in a paper r and when there are operations like L1-5L2->L2
then on the elemtary matrix part
they say
L1+5L2->L2
i was told that its because they was to create elementary matrices which are invertable to itself X=X^-1
E1*E2*E3*...*A=I
so
E1^-1*E2^-1*E3^-1..*E1*E2*E3*...*A=I*E1^-1*E2^-1*E3^-1..
so
A=E1^-1*E2^-1*E3^-1..
but the inverses are the as the originals so we just need to multiply the
elementary matrices
correct??
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
