Pressure and density of compressible fluids.
The discussion centers on the relationship between pressure and density in compressible fluids, particularly under the assumption of constant temperature. It is established that while density increases with pressure, the relationship is approximately linear over limited pressure ranges. The ideal gas law, expressed as p = ρRT, illustrates how pressure, density, and temperature are interrelated, with temperature directly affecting both pressure and density. Liquids are generally considered incompressible, making the ideal gas law more applicable to gases.
  • Understanding of the ideal gas law (p = ρRT)
  • Knowledge of compressible fluid dynamics
  • Familiarity with the concepts of pressure and density
  • Basic thermodynamics principles related to temperature effects
  • Research the ideal gas law and its applications in fluid mechanics
  • Explore the behavior of real gases and deviations from ideal gas behavior
  • Learn about compressibility factors in different fluids
  • Investigate equations of state for liquids and their applications
This discussion is beneficial for students and professionals in engineering, physics, and fluid dynamics, particularly those focusing on thermodynamics and compressible fluid behavior.
Nathanael
If a fluid is compressible, will the density be directly proportional to the pressure?
(I'm sure there's a limit where an increase in pressure stops producing a change in density, but I'm talking about for more "normal" (smaller) amounts of pressure.)
Are you assuming constant temperature as well?
Temperature would effect the energy, right?
And pressure is essentially the density of energy, (Newton-Meters per Cubic Meter)
So wouldn't a change in temperature only effect the pressure? And so it doesn't really need to be considered when considering the relationship between pressure and density, right?
Or no?
The word "proportional" has a certain exactness to it, and nothing is exact. The most one can say is that the density increases with increasing pressure. Over limited regions of pressure, the density change is approximately proportional to the pressure change.
Chet
Well, if temperature affects pressure and pressure in turn affects density then the conclusion is that temperature would also affect density.
Or no?
Or no?
I think Nathanael, in his original post, was referring to the effect of pressure on density at constant temperature. At least that was my interpretation.
Nathanael, is that what you meant?
Chet
Or no?
Sorry, I wasn't thinking about my last post. I was under the unexamined impression that a change in pressure caused by temperature would affect the density (simply because it affects pressure) but now that I'm thinking about it, I realize that a change in pressure caused by temperature will have no effect on density (right?).
Chet
In a sense I was talking about constant temperature, (in the sense that temperature was not a part of my picture) but honestly I didn't think about temperature.
(I never learned or thought of temperature affecting pressure, even though it's a common-sense kind of idea.)
My original question was just asking is if the increase in density was (approximately) linear, or if it curved upward, or curved downward, (or what I really mean is does it "bend" downward) or what?
That answers the question. Thanks.
Temperature absolutely and directly affects the pressure and density. For example, many gases behave as ideal gases at most ordinary conditions and so very closely follow the ideal gas law, which can be expressed as
$$p = \rho R T$$
where ##p## is pressure, ##\rho## is density, ##R## is the specific gas constant, and ##T## is temperature.
Liquids are generally nearly incompressible so usually this isn't a concern. You can likely find a similar equation of state for liquids like water but I don't know it off the top of my head and it won't be terribly useful.
Real gases generally follow a similar pattern to ideal gases but with various corrections and variations on things like exponents depending in the gas in question and the phenomenon causing it to behave non-ideally.
  • · Replies 40 ·
  • · Replies 48 ·
  • · Replies 20 ·
