Pressure and displacement amplitudes
The discussion centers on calculating the pressure amplitude of a sound wave with a known displacement amplitude of 4 µm at a frequency of 3 kHz. Participants suggest using the relationship between pressure and displacement in a sinusoidal wave, referencing the adiabatic compression of air. The relevant equations include the bulk modulus (B) and the density of air (p), with a focus on how pressure changes with displacement. There is some confusion regarding the definition of B, with participants clarifying that it represents the bulk modulus of air. The conversation emphasizes the need to show work to facilitate assistance in solving the problem.
Kaisean
I'm having some trouble on this problem.
"The human ear is most sensitive to sounds at about f = 3 kHz. A very loud sound at that frequency would have a displacement amplitude of about 4um. What is the pressure amplitude? (Assume the wave to be sinusoidal. For air at room temperature, B = 1.42 x 10^5 Pa and p = 1.20 kg/m^3.) Compare this to the typical diurnal variation in atmospheric pressure, about 500 Pa = 0.005 atm."
What equations would you use to start working on this problem? You need to show some of your own work in order for us to help you.
p is \rho = density of the air. I am not sure what pressure B is. Standard air pressure is 1.013x10^5 Pa. What is B?
To do this problem, consider a single wavelength of sound \lambda and the space of some volume of air A\lambda where A is the surface area of the wavefront.
In the compression part of the wave, the volume of air is reduced by A x displacement. Since it happens very quickly, it can be treated as an adiabatic compression (no time for heat to be lost). What is the change in pressure? Use:
PV^\gamma = K
AM
I would start with the constitutive relationship
P = P0 - Bds/dx
I'm given a B and p; however, no P0. Since this is displacement though, I only need to measure by how much this pressure varies so therefore I get P = Bds/dx where the "-" disappears since I am calculating only for a magnitude of change. I think that s(x, t) can take on the form of s(x, t)=S0sin kx cos wt and from there plug in for ds/dx assuming maximum change in s.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
