Calculating Pressure and Volume Increase on Rising from Depth d
In summary, the conversation discusses a diver rising quickly to the surface from a depth d and the resulting expansion of the lungs if the diver does not exhale gas before rising. The solution involves using the equations P1V1=P2V2 and P2=P1+pgd, with the density of seawater, ρ, and atmospheric pressure, Patm, to express the expansion factor in terms of d, ρ, g, and Patm. The suggested solution is V1=V2Patm/(1-pgd).
dimpledur
194
A diver rises quickly to the surface from a depth d. If she did not exhale the gas from her lungs before rising, by what factor would her lungs expand? Assume the temperature to be constant and the pressure in the lungs to match the pressure outside the diver’s body. The density of seawater is ρ. Express your answer in terms of d, ρ, g, and Patm (atmospheric pressure).
P1V1=P2V2
P2=P1 +pgd
P2 (Patm) is a distance d below P1. SO,
P1V1=P2V2
Patm = P1 +pgd
P1 = Patm - pgd
(Patm - pgd)V1=PatmV2
V1 = V2Patm / (1-pgd)
is that right?
No one can tell?
Yes, that is correct. To further explain, the first equation you listed is Boyle's Law, which states that the pressure and volume of a gas are inversely proportional when temperature is constant. The second equation is the hydrostatic equation, which relates pressure to depth in a fluid. In this case, the pressure inside the lungs (P1) is equal to the atmospheric pressure (Patm) minus the pressure due to the weight of the water (pgd) at a depth d. The last equation you wrote is just rearranging the first equation to solve for V1. So, when the diver rises to the surface, the pressure outside and inside her lungs will be equal (P2 = Patm), and using the last equation, we can see that her lung volume will increase by a factor of (1-pgd)/Patm. This means that the lung volume will increase by a larger factor for deeper depths (larger d) and for denser seawater (larger ρ), but will decrease if the atmospheric pressure (Patm) increases.
What is the formula for calculating pressure increase on rising from depth d?
The formula for calculating pressure increase on rising from depth d is P = P0 + ρgd, where P is the pressure at depth d, P0 is the pressure at the surface, ρ is the density of the fluid, g is the acceleration due to gravity, and d is the depth.
How does depth affect pressure?
As depth increases, pressure also increases. This is because the weight of the fluid above an object increases with depth, leading to a greater force being exerted on the object and thus a higher pressure.
What is the relationship between pressure and volume?
Pressure and volume have an inverse relationship, meaning that as one increases, the other decreases. This is known as Boyle's Law, which states that at a constant temperature, the pressure of a gas is inversely proportional to its volume.
What is the SI unit for pressure?
The SI unit for pressure is pascal (Pa). It is defined as one newton per square meter (N/m²).
How does temperature affect pressure and volume?
As temperature increases, both pressure and volume also increase. This is known as Charles's Law, which states that at a constant pressure, the volume of a gas is directly proportional to its absolute temperature.
17K
