Pressure Field Equation / Differentials
The discussion centers on understanding the derivation of the Pressure Field Equation in fluid dynamics. The user seeks clarification on the notation, specifically the term \(\delta{y}/2\) in the context of pressure changes. It is explained that \(\delta{y}\) represents the length of one side of a box, while \(\Delta{y}\) refers to the distance from the center of the box to a side, hence the division by two. The user finds a linked resource more helpful than their textbook, which complicates the notation. Overall, the conversation emphasizes the importance of clear representation in fluid dynamics equations.
MacLaddy
Hello folks,
I am having difficulty comprehending some material in my fluid dynamics course. This is not a homework question, just something missing in my understanding.
When proving the "Pressure Field Equation," (something I am not yet able to do) there is a series of steps my instructor took.
P=P_1+\Delta{P}
P=P_1+\Delta{y}\frac{dp}{dy}
Which somehow, magically, leads to...
F_y = (P+\frac{\partial{p}}{\partial{y}}\frac{\delta{y}}{2})*\delta{x}\delta{z}
So my question is this.
\frac{dp}{dy} is simply the change of P wrt y
\frac{\partial{p}}{\partial{y}} is the change of p wrt y in a particular direction, or part of the gradiant.
But what in the sam is \frac{\delta{y}}{2}?
Why the delta?
Any help would be appreciated.
Thanks,
Mac
fzero said:
If you're dealing with a scenario as in the figure at http://www-mdp.eng.cam.ac.uk/web/library/enginfo/aerothermal_dvd_only/aero/fprops/statics/node5.html, then ##\delta y## is the length of one side of the box. The distance ##\Delta y## that appears in your equation is the distance between the center of the box and the appropriate side, which is ##\delta y/2##.
Great, thank you for the link. That is a better representation then my textbook provides. It treats the lengths as ##\delta y##, whereas this link just shows the lengths as dx, dy, and dz. It seems a new character was introduced without any real need.
Mac
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
