Pressure of balls bouncing on area
The discussion revolves around calculating the average pressure exerted by 100 balls, each weighing 5g, that bounce from a height of 1m after being dropped from 3m onto a 2m² area. The pressure is determined using the formula pressure equals force divided by area, where force is derived from the change in momentum of the balls. A participant struggles with the calculations, initially arriving at an incorrect pressure of 0.81 Pa instead of the expected 3 Pa. The error was identified as a misunderstanding of the momentum's direction during the balls' descent and ascent. The conversation highlights the importance of correctly applying physics principles to solve the problem accurately.
LoN
a 5g balls fall dropped from 3m bounces up 1m. if 100 such balls fall on an area of 2m^2 every second what is the average pressure exerted by the balls?
ive tried to solve this problem 100 different ways and i can't get the answer (3Pa).
LoN, you wouldn't happen to have a Physics 213 midterm tonight at 7pm, would you? ;)
Pressure is force/area and force is (change in momentum)/time. You're provided with the area and time, so all you have to find is the change in momentum of the ball as it hits the surface.
haha yes i do. small world eh :biggrin:
i must not be setting this up right, here's what I am doing.
1/2 m v^2 = mgh solve for v for each height, 1 m and 3m.
then find the change in momentum by multiplying the vs i have solved for by the mass of the ball and subtract. i get .0162 for the change in momentum. so then i multiply that by 100(?) and divide by 2m^2 and i end up with .81Pa
where am i screwing up :confused:
Remember that the momentum as the ball is going down is negative, and the momentum as the ball is going up is positive.
Good luck tonight!
thanks for the help, what a lame mistake i was making
