Pressure on a Dam: Calculating Force & Torque
  • Thread starter Thread starter Kalie
    Pressure
As water fills the reservoir behind a dam, the pressure exerted increases significantly, potentially leading to structural failure if the dam's materials cannot withstand the force. The pressure on the dam is calculated using the formula rho*g*h, where rho is water density, g is gravitational acceleration, and h is depth. The force on a horizontal layer of the dam wall can be determined by multiplying the pressure at that depth by the area of the strip. Additionally, the water's force generates torque about the dam's base, which can lead to pivoting if it exceeds the dam's structural limits. This scenario requires integral calculus to accurately assess the forces and torques involved.
Kalie
As the reservoir behind a dam is filled with water, the pressure that the water exerts on the dam increases. Eventually, the force on the dam becomes substantial, and it could cause the dam to collapse. There are two significant issues to be considered: First, the base of the dam should be able to withstand the pressure rho*g*h, where rho is the density of the water behind the dam, h is its depth, and x is the magnitude of the acceleration due to gravity. This means that the material of which the dam is made needs to be strong enough so that it doesn't crack (compressive strength).
http://session.masteringphysics.com/problemAsset/1011118/16/SFL_pl_5.jpg
Consider a horizontal layer of the dam wall of thickness located a distance above the reservoir floor. What is the magnitude dF of the force on this layer due to the water in the reservoir?
The force of the water produces a torque on the dam. In a simple model, if the torque due to the water were enough to cause the dam to break free from its foundation, the dam would pivot about its base (point P). What is the magnitude tau of the torque about the point P due to the water in the reservoir?
Well on part A I found the pressure, vertical height above the floor of the reservoir
p(x)=pg(h-x) but I don't know what to do from there. There are no values so it is just letter variables
It will probably help you to assume the dam has a width L so that you can calculate the area of a strip at a given depth. The pressure at that depth exerts a force on the strip that is the pressure times the area of the strip. The torque that you calculate will actually be the torque about a line through point P, and it will be proportional to L. The wider the dam, the greater the force on the dam and the greater the torque. As you probably already realize, this is an integral calculus problem.
Beams of electrons and protons move parallel to each other in the same direction. They ______. a. attract each other. b. repel each other. c. neither attract nor repel. d. the force of attraction or repulsion depends upon the speed of the beams. This is a previous-year-question of CBSE Board 2023. The answer key marks (b) as the right option. I want to know why we are ignoring Coulomb's force?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
I treat this question as two cases of Doppler effect. (1) When the sound wave travels from bat to moth Speed of sound = 222 x 1.5 = 333 m/s Frequency received by moth: $$f_1=\frac{333+v}{333}\times 222$$ (2) When the sound wave is reflected from moth back to bat Frequency received by bat (moth as source and bat as observer): $$f_2=\frac{333}{333-v}\times f_1$$ $$230.3=\frac{333}{333-v}\times \frac{333+v}{333}\times 222$$ Solving this equation, I get ##v=6.1## m/s but the answer key is...
