Pressure Variation in Planetary Atmosphere
The discussion focuses on the mathematical relationship between pressure and altitude in a planetary atmosphere, assuming constant temperature. It presents the equation p = poek(1/r-1/R) to describe pressure variation, where g varies as 1/r^2. The relationship between density and pressure is established with P/Po = p/po and the differential equation dP/dy = -pg. The participants clarify that changes in height can be represented as dr = dy, reinforcing the connection between pressure and gravitational effects. This analysis emphasizes the importance of understanding atmospheric pressure dynamics in planetary science.
BreakingBad
1. Show that the variation of pressure with altitude for a planetary atmosphere (assuming constant temperature) is more accurately given by: p = poek(1/r-1/R), where g is taken to vary as 1/r2 (with r being the distance from the centre of the planet), po is the pressure at the surface, R is the radius of the planet, and k is a constant.
lower case p = pressure
upper case P = density
2. P/Po = p/po
dP/dy = -pg
3. dP/P = -g(po/Po)dy
g = k/r^2 and since both dy and dr represent a change in height dr = dy
Thank you, makes sense.
