Primitive n-th Roots of Unity: Showing e^{i2\pi k/n}
  • Thread starter Thread starter autre
    Primitive Roots
autre
Show that primitive n-th roots of unity have the form e^{i2\pi k/n} for k\in\mathbb{Z},n\in\mathbb{N}, k and n coprime.
The attempt at a solution
So the n-th roots of unity z have the property z^{n}=1. I have previously shown that (e^{2\pi ik/n})^{n}=e^{2\pi ik}=(e^{2\pi i})^{k}=1^{k}=1. However, I'm not sure where to start in proving that primitive n-th roots of unity have that property. Any ideas on where I could get started?
The problem isn't to show that if z is a primitive n-th root of 1 that z^n=1. You know that. A primitive n-th root of 1 is also an n-th root of 1. What's the definition of a primitive root?
A primitive n-th root has the smallest such n that z^n = 1. So if k and n aren't coprime then they would have a common factor except 1, because if they did, you could have a smaller n s.t. z^n = 1.
Well, yes, that's the really sloppy explanation.
We never covered it in class so I've had to make do with various online sources and have had some difficulty coming up with a formal definition to help me with the proof (though I basically understand what's going on). Do you have a moreformal definition that I could use as a starting point? Thanks!
z is a primitive nth root of unity if z^n=1 and z^k \ne 1 for 0<k<n.
How's this for starters?
Let z\in\mathbb{C} be a primitive n-th root of unity. Then, for n\in\mathbb{N} and k\in\mathbb{Z} s.t. 0<k<n ,z^{n}=1 and z^{k}\neq1. Suppose n=jk for some j\in\mathbb{Z}. Then, since z is a root of unity, z=e^{2k\pi i/n} and z^{k}=z^{n/j}=e^{(2\pi ik/n)^{n/j}}=e^{(2\pi ik)/j}=(e^{2\pi i})^{k/j}=1^{k/j}=1. But z^{k}\neq1.
I know I've only proven (or tried to) that n is not a multiple of k. Any ideas on what I'm missing?
If n and k are not coprime then there is an s>0 such that n=sn' and k=sk'.
How about this?
Let z\in\mathbb{C} be a primitive n-th root of unity. Then, for n\in\mathbb{N} and k\in\mathbb{Z} s.t. 0<k<n ,z^{n}=1 and z^{k}\neq1. Suppose k and n are not coprime. Then, \exists s\in\mathbb{N} s.t. n=sn' and k=sk' for some k'\in\mathbb{Z},n'\in\mathbb{N}. Then, since z is a root of unity, z=e^{2k\pi i/n} and z^{k}=z^{nk'/n'}=e^{(2\pi ik/n)^{nk'/n'}}=e^{(2\pi ik)k'/n'}=(e^{2\pi i})^{kk'/n'}=1^{kk'/n'}=1. But z^{k}\neq1. Contradiction, so k, n coprime.
autre said:
How about this?
That 'proof' should be making you feel at least a little uncomfortable. Pick n=6 and k=2. You are claiming z^2=1? That's not true. Tell me what's wrong with it.
Do I need to exclude 2 somehow? It seems like 2 is the only prime number where the proof would fail.
Pick n=15 and k=3. z^3 still isn't 1. Put the numbers in and trace through your steps in the proof. Figure out where something fishy happens.
Ah, the problem seems to be that I should have s\neq k.
You are just guessing. Look at this. e^\frac{2 i \pi}{3}={(e^{2 i \pi})}^\frac{1}{3}=1^\frac{1}{3}=1. True or false?
e^\frac{2 i \pi}{3}\neq{(e^{2 i \pi})}^\frac{1}{3}. That was some sloppy algebra on my part -- x^{2/3}=(x^{2})^{1/3} iff x>0.
You have to be careful. Fractional powers of complex numbers aren't well defined. It's only 'safe' to say (a^b)^c=a^(b*c) if c is an integer. You are throwing fractional powers around in your 'proofs' in a bad way.
Okay, so going back to k=sk' and n=sn', can I use the fact that for s>1, n/s \leq n but z^{n/s}=e^{2\pi i(k/s)}=1? Or am I still using fractional powers improperly?
No. That's fine. n/s=n' is an integer. So your are allowed to bring that into the power of the exponent. And k/s=k' is an integer. So, sure, you get 1.
