Probability and gauss integral
squaremeplz
1) Find the area under the curve for:
a) P( 0 <= Z <= 2.07)
b) P(-.64 <= Z < -.11)
c) P( Z > -1.06)
d) P(Z < -2.33)
e) P(Z >= 4.61)
2) a) Evaluate integral from 0 to 1.24 of e^(-x^2/2)
b) Evaluate the integral from -inf to inf of 6*e^(-x^2/2)
Z value table
Power series expansion of e^x
a) Fz(2.07) - Fz(0) = .9808 - .5 = .4808
b) Fz(-.64) - Fz(a) = .4247 - .2611 = .163
c) 1 - Fz(-1.06) = .85
d) .0104
e) .00002
Can someone explain to me the difference in calculating an area where Z < x vs. Z <= x. Do I just use the value closest to x and less than it on the table for Z < x?
2) a)I used the power series expansion and dervied each term upto n = 4 and got
.6807
b) No clue how to do this. Polar coordinates?
With the standard normal distribution (indeed, any continuous probability distribution)
there is no difference working with &lt; and \le, so that
<br /> P(Z &lt; z) = P(Z \le z)<br />
As an example
<br /> P(Z &lt; 1.24) = P(Z \le 1.24)<br />
Both can be found from a table or software.
For the integral problem, consider this. If I use Z = 2.1
\begin{align*}<br /> P(Z \le 2.1) &amp; = \int_{-\infty}^{2.1} \frac 1 {\sqrt{2 \pi}} e^{-{x^2}/2} \, dx\\<br /> &amp; = \int_{-\infty}^0 \frac 1 {\sqrt{2 \pi}} e^{-{x^2}/2} \, dx + \int_0^{2.1} \frac 1 {\sqrt{2 \pi}} e^{-{x^2}/2} \, dx \\<br /> &amp; = 0.5 + \frac 1 {\sqrt{2 \pi}} \int_0^{2.1} e^{-{x^2}/2} \, dx<br /> \end{align*}<br />
If you rearrange terms you find that
<br /> \int_0^{2.1} e^{-{x^2}/2} \, dx = \sqrt{2 \pi} \left(P(Z \le 2.1) - .5 \right)<br />
None of the terms on the right require a series expansion.
This idea should help you with your integral questions.
Great explanations.
a) = sqrt(2pi) * (P(Z <= 1.24) - .5)
b) = sqrt(2pi)/6
Is this right? Thanks.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
