Probability (density function)
forty
A point is selected at random and uniformly from the region
R = {(x,y): |x| + |y| <= 1 }
Find the probability density function of the x-coordinate of the point selected at random.
By definition f(x) = the integral of f(x,y) over all y values.
after this I'm pretty much stuck. does f(x,y) = 1/4? I mean the definition is simple I think it's just me not knowing how to deal with the modulus signs.
(Is the region a square(diamond) intersecting at (0,1)(1,0)(-1,0)(0,-1))
Any help always appreciated.
Thanks.
Your diamond is right. You are right that f_{XY}(x,y) is constant, but you have the wrong constant, because the area of that diamond is not 4.
You could split the diamond into two halves, the case where x>0 and the case where x<0. Then you can obtain equations for the boundary lines without using absolute value. Your f_X(x) could then be piecewise defined.
When you are done, you could try to combine the piecewise defined f_X(x) into one formula using absolute value, if you want, or simply leave it piecewise defined.
f(x,y) = 1 (was looking at the diamond thinking it had side lengths of 2 :S, hope this is right now)
as for the integrals I am still having trouble...
for x > 0
f(x) = integral(from x-1 to -x+1) of 1 dyfor x < 0
f(x) = integral(from -x-1 to x+1) of 1 dy
are these even remotely correct?
I end up with 2-2x for x>0
and 2+2x for x<0
which if i combined them i get 2(1-|x|)
the answer in the book is just 1-1|x|... when i combine them do i drop the 2 :P
Your f(x,y) is still wrong. What is the area of that diamond? When you fix it, you will get what they got.
Thanks for the help Billy! Once i fixed up f(x,y) (dont ask me why it took me so long to realize that the area wasn't 1 :S) it all worked out!
Thanks again!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
