Probability - Men and women meeting
  • Thread starter Thread starter Robin04
    Probability Women
The discussion focuses on calculating the probability of friendships formed between men and women using binomial distribution. Participants explore how to model the number of friends as discrete random variables, applying the formula for binomial probabilities. They discuss combining independent variables from two groups, leading to the conclusion that the total number of trials should be represented as M + N. The conversation also touches on the artificial nature of the problem, questioning the equal probability of forming friendships. Ultimately, the correct approach involves considering the total opportunities for friendship as Bernoulli trials.
Robin04
There are N women and M men on a party. They can make friends with the same gender one by one independently with ##p## probability. Men and women cannot make friends. What's the probability that if we choose a man and a woman, the sum of their friends they got to know is ##k##.
I'm not sure how to start this. Can you give me a little hint?
Try considering it is just M number of people with probability p. For example say it's 3 people. So a person can have either 1 friend or 2 friends. Once you figure you this situation works, then consider men as a group, pick 1, then women is a separate group, pick 1.
Are you familiar with discrete random variables? This particular problem could be solved by applying binomial distribution.
So the variable that stands for the number of friends of a man or woman follows the binomial distribution. Wikipedia: ##\Pr(X = k) = \binom{n}{k}p^k(1-p)^{n-k}## where ##n## can be M and N, and ##p## is the same ##p## as in our problem. We have now two independent variables. How to get that probability that their sum is a certain value?
Isn't that what you have calculated?
Hint: can you combine the ##M + N## trials?
Robin04 said:
I found this: https://math.stackexchange.com/questions/1176385/sum-of-two-independent-binomial-variables
According to this the sum of two binomials is another binomial with the sum of their parameters, so ##n## has to be substituted by ##M+N##, right?
If you want a total of ##k## successes from two sets of ##M## and ##N## trials, then isn't that the same as ##k## successes from ##M + N## trials? Assuming they are all independent.
The problem is a bit artificial as why would there be the same probability of making a friend in each case? If, instead, each man tossed a coin ##M## times and each woman tossed a coin ##N## times, then the probablity they have ##k## heads between them is clearly the same as if one person had tossed a coin ##M + N## times.
That said, are ##M## and ##N## correct for the number of trials?
Likes scottdave and Robin04
Robin04 said:
so n has to be substituted by M+N, right?
Almost there. Maximally how many friends can one make?
N-1 and M-1
That looks better
lomidrevo said:
That looks better
So n is N+M-2? But why?
Yes, that should be correct. Binomial distribution ca be seen as a sum of ##n## indepedent Bernoulli trials. Each opportunity for a friendship in this example is a Bernoulli trial. So for ##n## you have to use the total number of opportunities to make a friendship (for the chosen woman and man)
