What is the probability of exactly one tall student out of two students?
  • Thread starter Thread starter neubreed
    Probability
The probability of selecting exactly one tall student out of two randomly chosen from a group of 50, where 26 are tall, is calculated as 624/1225. The approach involves determining the probabilities of two mutually exclusive events: one tall and one not tall, in either order. The calculations confirm that adding the probabilities of these events is correct. Additionally, the combinations formula can be used to verify the result, showing that the method is sound. The final answer of 624/1225 is consistent with the expected probability given the distribution of tall students.
neubreed
26 out of 50 total students are tall. If 2 different students are called on at random, what is the probability that exactly one is tall?
please see below
so here's what I ended up with:
1st student is tall: 26/50 x 24/49=312/1225
2nd student is tall: 24/50 x 26/49= 312/1225
I'm not sure whether I now multiply the two fractions or add them... Am I on the right track?
Thanks!
please see below
Thanks!
Yes, if you want to do it that way you are on exactly the right track. The two events you have are mutually exclusive. What do you think about the question of whether to add or multiply?
I'm leaning towards adding, but the end result seems a little high... Would 624/1225 be the asnwer?
Why is that "high"? It is just about 1/2 and just about 1/2 of the students are "tall".
If A and B are "equally likely" (probability of each 1/2) then "AA", "AB", "BA", and "BB" all have probability 1/4 so AB+ BA has probability 1/2.
Yes, it is. You can check it using the combinations formula C(n,k) if you know that. There are C(26,1) ways to choose the tall, C(24,1) ways to choose the other and C(50,2) ways total ways to choose 2 students. C(26,1)*C(24,1)/C(50,2)=624/1225.
