Probability that X1=0 given that N=1
  • Thread starter Thread starter DottZakapa
    Probability
DottZakapa
Given ##X_1,X_2,X_3## three independent random variables that can assume values 1 ,0 ,-1 with probabilities ##\frac 1 4 ,\frac 1 2 ,\frac 1 4 ##. Let ##S=X_1,X_2,X_3## and let N be the number of##X_i## assuming value ##0##
Probability
Given ##X_1,X_2,X_3## three independent random variables that can assume values 1 ,0 ,-1 with probabilities ##\frac 1 4 ,\frac 1 2 ,\frac 1 4 ##. Let ##S=X_1,X_2,X_3## and let N be the number of##X_i## assuming value ##0##.
Knowing that N=1 i have to find what os the probability of ##X_1=0##, that is:
##P \left[ X_1=0 | N=1 \right]= ##
##P \left[ N=1 \right]= \binom 3 1 * \frac 1 2 *\left(\frac 1 2 \right)^2 ##
so i can do
##P \left[ X_1=0 | N=1 \right]=\frac {P \left[ X_1=0 \right] P \left[ N=1 | X_1=0 \right]} {P \left[ N=1 \right]}##
now comes the question
in ##P \left[ N=1 | X_1=0 \right]## starts counting ignoring that ##X_1 = 0## so in order to have N=1 there is an other random variable that is equal to 0 and one that is not, ##X_1=0, X_2=0, X_3 \neq 0##
or
only ##X_1=0## and the others are not equal zero?
Based on the definition of ## N ## that you provided, I think your latter scenario is correct (i.e. ## X_1 = 0 ## and the other two are non-zero)
In terms of the solving, I think Bayes' might overcomplicate it? I think it might be quicker to do the calculation w/o Bayes'. (EDIT: don't change the way you solve it just based on my comment because both methods should yield the same answer - perhaps you use another method as a checking mechanism)
Master1022 said:
Based on the definition of N that you provided, I think your latter scenario is correct (i.e. X1=0 and the other two are non-zero)
if## X1=0## and the other two are non-zero then the result does not coincide with the result (according to the prof correction) which is 1/3.
My solution is :
##P \left[ X_1=0 | N=1 \right]=\frac {P \left[ X_1=0 \right] P \left[ N=1 | X_1=0 \right]} {P \left[ N=1 \right]}=## ##\frac {\frac 1 2 \frac 1 4 \frac 1 4 }{\binom 3 1 \frac 1 2 \left(\frac 1 2 \right)^2}##
while the professor did as follows :
##\frac {\frac 1 2 \frac 1 2 \frac 1 4 }{\binom 3 1 \frac 1 2 \left(\frac 1 2 \right)^2}##
he considered also the second random variable as = to zero and i don't understand why
My solution is :
can you explain why the numerator is ## \frac{1}{2} \cdot \frac{1}{4} \cdot \frac{1}{4} ## instead of ## \frac{1}{2} \cdot \frac{1}{2} \cdot \frac{1}{2} ## as the probability of being non-zero is 1/2?
I am not sure why he considered a second variable as 0, but will give that more thought afterwards as well. Is it potentially a typo as that expression doesn't = 1/3? I think he meant the numerator to be ## ( \frac{1}{2} )^3 ##
I thought the solution would follow:
$$ = \frac{ P(X_1 = 0) P(X_2 \neq 0) P(X_3 \neq 0) }{ P(X_1 = 0) P(X_2 \neq 0) P(X_3 \neq 0) + P(X_1 \neq 0) P(X_2 = 0) P(X_3 \neq 0) + P(X_1 \neq 0) P(X_2 \neq 0) P(X_3 = 0)} $$
which yields ## 1/3 ## as expected
DottZakapa said:
My solution is :
I think there is an error with you numerator. If you list out all the combinations of ## X_1 ##, ## X_2 ##, and ## X_3 ## where ## X_1 = 0 ##, there will be 9 combinations. However, not all combinations are equiprobable (as ## P(X_i = \pm 1) = 1/4 ## each). When I calculated ## P(N = 1 | X_1 = 0) ##, those are the cases where only ## X_1 ## is 0, then I get ## 1/4 ## so your numerator would be ## \frac{1}{4} \cdot \frac{1}{2} = \frac{1}{8} ## which will yield 1/3
i am getting lost
so
tho probability of being 0 is 1/2
probability of being 1 or -1 is 1/4
then, for what concerns
##P \left[ N=1 | X_1=0 \right]## = ##P(X_1=0,X_2=1,X_3=1)+P(X_1=0,X_2=1,X_3=-1)+##
##P(X_1=0,X_2=-1,X_3=1)+P(X_1=0,X_2=-1,X_3=-1)+P(X_1=0,X_2=-1,X_3=-1)##
in which i am taking into account all possible combinations where ##X_1=0##.
so it becomes
##\left(\frac 1 2 \frac 1 4 \frac 1 4 \right)*4##
this solves
but in front of it there also is
##P \left[ X_1=0 \right] ## that is equal to ##\frac 1 2##
agree
agreed
so it becomes
this solves
I believe this is calculating ## P(N = 1 \cap X_1 = 0) ## rather than ## P \left[ N=1 | X_1=0 \right] ##. You need to divide by ## P(X_1 = 0) ## to get
$$ P \left[ N=1 | X_1=0 \right] = \frac{4 \cdot \frac{1}{2} \cdot \frac{1}{4} \cdot \frac{1}{4}}{1/2} = 1/4 $$
Then when you include the extra factor of 1/2 that you mentioned you will get 1/8
Does that make more sense. If not, I think listing out all 9 combinations and finding the probability of each will help calculate this term
Apologies, I can see how this may have been misleading. What I meant here was that I listed out all the combinations where ## X_1 = 0 ## and found ## P(N = 1 | X_1 = 0) ## by doing:
sum of probabilities where ONLY ## X_1 = 0 ## / sum of probabilities of those 9 combinations
Master1022 said:
## \frac{4 * \frac{1}{2} * \frac{1}{4} * \frac{1}{4}}{1/2} = 1/4 ##
ok ok, now its all clear. all works.
thank you.
Likes Master1022
yes i understood that, and being also multiplied by ##P(X_1 = 0)## i remove from the other probability (by dividing because already taken into account ).
