Problem in magnetic effects of current
The discussion centers on determining the correct formula to calculate the magnetic force exerted on an electron moving parallel to a current-carrying wire. Participants clarify that the relevant equation depends on whether the force is being calculated for a single charge or a current-carrying wire. The formulas mentioned include f = BqV sin(θ) for a charge, f = BIl sin(θ) for a wire, and a formula for the force between two wires. The key takeaway is to identify whether the scenario involves a single charge or a wire to select the appropriate equation. Understanding this distinction is crucial for solving the problem accurately.
logearav
a long straight wire carries a current of 2A. an electron travels with a speed of 4*10^4 m/s parallel to the wire at a distance of 0.1 metre from it. what force does the magnetic field exert on the moving electron
what formula should i use? is it f= BqV SIN\theta or f= BIl sin\theta
or f=4*3.14*10^-7* I1*I2* L)/(2*3.14*a)
he attempt at a solution[/b]
A reasonable question. Here's a hint: does the question ask for the force on a single charge, or the force on a current-carrying wire?
"a long straight wire carries a current of 2A. an electron travels with a speed of 4*10^4 m/s parallel to the wire at a distance of 0.1 metre from it. what force does the magnetic field exert on the moving electron"
the problem is like this. nothing mentioned extra.
You didn't really answer my question, which was meant to be a hint to help you decide which equation to use.
To make my point clearer:
That is the force on a charge q moving with speed V.
... or f= BIl sin\theta
This is the force on a wire of length l and current I.
... or f=4*3.14*10^-7* I1*I2* L)/(2*3.14*a)
This one is the force between two wires of length L.
So, to figure out which equation applies here, you need to figure out if you need the force on a single charge, the force acting on a single wire, or the force acting between a pair of wires.
