Problem on conservation of energy/momentum
  • Thread starter Thread starter siddharthmishra19
    Conservation
The discussion revolves around a physics problem involving the conservation of energy and momentum when a particle breaks into two pieces. Participants clarify that even with an initial momentum of zero, the conservation of momentum can still be applied, as the two resulting pieces will move in opposite directions. The equations for kinetic energy and momentum are established, leading to the conclusion that the velocities of the pieces can be derived from these principles. The conversation also touches on the need to consider vector components when analyzing momentum, especially in cases where the pieces move at angles to each other. Overall, the key takeaway is the importance of applying both conservation laws correctly to solve the problem.
siddharthmishra19
A particle breaks into two pieces m1 and m2 traveling with velocities v1 and v2 respectively. The total kinetic energy of the particles is E. What is the velocity of each particle?
Law of conservation of energy
Law of conservation of momentum
Obviously as total kinetic energy is E,
m_1v_1^2/2 + m_2v_2^2/2 = E
I don't know if I'm allowed to use conservation of momentum because initial momentum is 0 and suddenly it is m1v1 + m2v2...
The problem only makes sense if the original (non split) particle has a nonzero momentum. I think you are supposed to solve for the original velocity.
The fact that the initial momentum is 0 is not a problem-- that tells you they travel in opposite directions, right?
There is no original velocity, the particle is at rest.
Hmm... that's possible but only is the momentum of the the split particles is equal ... can anyone verify this?
This problem makes more sense:
A body (mass M) is moving with velocity Vo. It breaks into two pieces, one of which (mass m) is traveling with speed V1 in the direction perpendicular to Vo. What is the speed of the other piece.
Mass of other piece is (M-m). The problem I am finding is I don't know the direction of the second piece so I can project it into suitable axis. Or is it not needed?
I tried solving using conservation of energy (kinetic) but obviously ended up with wrong answer because the fact that the speed of first piece is perpendicular to original direction is not used...
Good.
Sure you can. (You must!) Realize that momentum is a vector: one of those velocities will be positive, the other negative.
0 is a perfectly legitimate velocity!
This is a conservation of momentum problem. Remember that momentum is a vector. Hint: Call the original direction to be along +x. What's the y-component of the total momentum?
Thanks, Doc! I think I've got it... please verify!
P.S. This is my first attempt to use LaTeX... forgive if something goes wrong.
According to problem, total kinetic energy of the particles is E
Initial momentum = O (system at rest)
New momentum = m_1v_1 - m_2v_2
Assuming the above is correct and momentum is conserved,
m_1v_1 = m_2v_2
Two equations with two unknowns!
Solving,
v_1 = sqrt(2Em_2/m_1(m_1+m2))
V2 is found the same way, and it will also be +ve. I'm assuming that is the modulus of speed, because in the book the other is -ve.
About the other problem... original velocity is along x-axis so y component is 0.
Since after splitting momentum is conseved then along the y-axis the momentum of the second particle will cancel out the one of the first particle and will also be along the y-axis in the opposite dir. (perpendicular to original velocity). m1v1=m2v2.
Is that what you mean? If so then why can't it be that the velocity of the second particle is at some angle "A" from the vertical and m1v1 = m2v2cosA ?
Solving,
Looks good to me! (I see you took v_1 to be the magnitude of the speed of mass 1 and v_2 to be the magnitude of the speed of mass 2; no problem.)
Good.
The y-component of the second particle's momentum must be equal and opposite to the y-component of of the first particle's momentum.
Now figure out the x-component of its momentum.
The momentum (and thus velocity) of the second particle will surely be at some angle. Figure it out by finding the components of its momentum.
Yes but the angle is not give. Could that be a problem?
Why is that a problem? If you solve for the x & y components of momentum, you can figure out the angle if you wanted to. (But why bother? All you really need to find is the magnitude.)
Thanks doc, you're a lifesaver... another question I can't seem to grasp...
Two particles (mass m1 and m2) are moving on a horizontal plane with speeds v1 and v2. Angle between them is A. What is the total momentum.
Won't it just be m1v1 + m2v2cosA? In the book its give as sqrt((m1v1)^2 + (m2v2)^2 + 2m1v1m2v2cosA)... (or something of this form)... I just can't seem to grasp the concept.
Looks like you are taking the momentum of the first particle (say it's moving in the +x direction) and then adding just the x-component of the second particle's momentum. That just gives you the x-component of total momentum. What about the y-component of the second particle's momentum?
I see too. Thanks!
I was really scratching my head about where the momentum came from.
