Problem on the magnetic force on a wire
The discussion focuses on calculating the magnetic force on a wire carrying a current in a magnetic field. The wire is 42.1 cm long and carries a 0.660 A current, with specified magnetic field components. The initial calculations for the y and z components of the force yielded incorrect results. Participants suggest re-evaluating the cross-products and ensuring the wire length is correctly incorporated in the calculations. The importance of showing detailed work and using the correct determinant setup is emphasized for accurate results.
electrohau5
A wire 42.1 cm long carries a 0.660 A current in the positive direction of an x-axis through a magnetic field with an x component of zero, a y component of 0.000330 T, and a z component of 0.00840 T. Find the (a) x, (b) y, and (c) z components of the magnetic force on the wire.
Force on a wire:
F=i*(crossP(L,B))
Seems simple, but I am getting a wrong answer.
a. 0 (this is correct)
b and c. 0.660*(crossP({0.66,0,0}, {0,0.000330,0.00840})={0,-0.00365904,1.43748E-4}
and niether -0.00365904 (y component, part b),
nor 1.43748E-4 (z component, part c)
are correct.
electrohau5 said:
F=i*(crossP(L,B))
Check the number that you used for the length of the wire.
Do your cross-products again. Show us the details thereof. (Set up the customary determinant rather than your more obscure notation).
EDIT: follow TSny's advice! I hadn't noticed that you omitted the length.
Thanks! I did not see that one!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
