Problem: particle in infinitely deep potential
paly4
A square well: 0≤x≤L, V=0, for others x V=∞
ψ=N[x(x-L)+Ax2(x-L)+Bx(x-L)2]
H=-[STRIKE]h[/STRIKE]/2m*d2/dx2+V(x)
a) Determine N
b) Use the Rayleigh-Ritz variational method to obtain the <ψ|H|ψ> as a function of A and B, and minimize the energy with respect to A and B
c) Discuss how many distinct values of the pair (A, B) that you obtain and do you get more than one energy? If yes, what are they?
d) Compare you results to the exact particle in the box and discuss the error.
a') Consider the same system, but now V(x)=x for 0≤x≤L
Compute the first order perturbation correction to the ground state energy
b') Compute the first order perturbation correction to the ground state wave function
a) I found with SAGE mathematical software that N2=\frac{\sqrt{210}}{\sqrt{(2B<sup>2</sup>-3AB+2A<sup>2</sup>)L<sup>7</sup>+7(A-B)L<sup>6</sup>+7L<sup>5</sup>}}
b) I'm not sure in that. But I've calculated <E>=-[STRIKE]h[/STRIKE]/2m*∫ψ(x)*ψ''(x)*dx from 0 to L, it's another value depending from A, B and L.
I don't understand, what does "minimize the energy with respect to A and B" means. It already depends only from A, B and L.
c) It looks like that there must be some border values for energy, so it will be possible to determine A and B.
d) Exact particle is E=[STRIKE]h[/STRIKE]2/8mL2, just need to know A and B in the value from b) to compare.
a') <E>=-[STRIKE]h[/STRIKE]/2m*∫ψ(x)*(d2/dx2+x)[ψ(x)]*dx from 0 to L. Am I right in that solution? Or it is just -[STRIKE]h[/STRIKE]/2m*∫ψ(x)*(x)*ψ(x)*dx
b') have no idea, how to calculate correction for the ground state of the wave function.
The variational principle gives you an upper bound on the energy of the ground state; therefore, to get the best estimate, you want to find the least upper bound. In this case, your estimate will vary with A and B, so you want to find the value or values of A and B that minimize the function.
Thank you.
I've got 3 values of the <E>=5, 7 and 21 *([STRIKE]h[/STRIKE]2/mL2) after the finding derivatives of <E> with respect to A, B and AB.
So, the minimum of <E> is 5([STRIKE]h[/STRIKE]2/mL2).
But I'm still stuck with a') and b').
Vela, thanks for helping me!
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
