Problem regarding complex numbers
The discussion revolves around solving a complex number equation involving real numbers m and x, where m is an integer. The user initially struggled with the problem and sought a systematic approach rather than trial and error, noting that substituting m=0 yielded the correct answer. Participants suggested exploring the inverse cotangent function and converting expressions like xi+1 into exponential form. Ultimately, the user confirmed they found the solution with assistance from the community. The conversation highlights the importance of understanding trigonometric identities and complex number conversions in solving such problems.
sankalpmittal
If m and x are two real numbers where m ε Integers, then e2micot-1x{(xi+1)/(xi-1)}m, (where i=√(-1)) is equal to :
(a) cos(x) + isin(x)
(b) m/2
(c) 1
(d) (m+1)/2
I seriously have no clear cut idea of how to proceed. I used this technique,
Since m is an integer, then I put m=0, and got the correct answer. :p
But I want a procedure, not a hit and trial method, of how to proceed.
I can write above as
{cos (2mcot-1x) + isin(2mcot-1x)}{(xi+1)/(xi-1)}m
But how to proceed after this ? Hints will do..
Please help !
Thanks in advance...:smile:
(b) m/2
(c) 1
(d) (m+1)/2
Please help !
First of all: what is meant by ##\cot^{-1} x?## (I know it, but do you?) Try to set ##y = \cot^{-1} x## and see where that gets you.
Hello sankalp!
Look at ##xi+1##. Can you convert it to e^{i*something}? :)
I know what it is. Its an inverse trigonometric function with range 0 to pi, boundaries exclusive. Are you insisting to substitute y with cot inverse x ?
Pranav-Arora said:
Hello sankalp!
Yeah. I got the answer. Thanks.
Rays approach also worked.
Thanks..
The question you asked in one post was from present fiitjee aits. Are you giving a second try for jee ?
