Problem understanding a proof in Spivak Vol. 4
  • Thread starter Thread starter SheldonG
    Proof Spivak
SheldonG
This is from Spivak, Vol. 4 Page 102-103
Given |x-x_0| < 1, |x-x0| < Epsilon/(2(|y_0|+1))
Also given |y-y_0| < Epsilon/(2(|x_0| + 1))
Prove |xy-x_0y_0| < Epsilon
See above
The proof proceeds clearly enough. Using |x-x_0| < 1, he shows that |x| < |x_0| + 1.
Then
|xy-x_0y_0| = |x(y-y_0) + y_0(x-x_0)|
< |x(y-y_0)| + |y_0(x-x_0)|
< (1+|x_x0|)*Epsilon/(2(|x0|+1)) + |y_0|*Epsilon/(2(|y_0|+1))
= Epsilon/2 + Epsilon/2 = Epsilon
So.. Q.E.D., but I do not understand the second term...
How is |y_0|*Epsilon/(2(|y_0| + 1)) = Epsilon/2 ??
Any help would be most appreciated. This is for self-study, so I am without a teacher.
Thanks,
Shelly
That term, in fact, is not equal to \epsilon/2, it's merely less than it.
Try verifying the inequality
|y_0| \cdot \frac{ \epsilon}{2(|y_0|+1)} &lt; \frac{\epsilon}{2}.
Spivak's book was my first introduction to rigorous calculus too. In these proofs I remember trying to equate everything (and having it never work). It's quite frustrating at first! Just remember analysis is all about inequalities.
EDIT: Oh! Did you notice that that equal sign in the fourth line of your proof is supposed to be a less-than sign? Maybe that's where you got mixed up...?
Stringy - thank you *so* much. That is a tremendous help.
Much appreciated!
Shelly
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
