Problem with prime and composite numbers
canningdevin
If p >= 5 is prime, prove that p^2 + 2 is composite.
So i noticed if we divide any p >= 5 by 6 we only get remainders of 1 or 5.
6 | 5 , r = 5
6 | 7 , r = 1
6 | 11, r = 5
6 | 13, r = 1
6 | 17, r = 5 and so on
so for my proof i am saying for p >= 5, p = 6k + 1 or 6k = 5
so for the first , p^2 + 2 = (6k+1)^2 + 2 = 36k^2 +12k + 3 = 3(12k^2 + 4k + 1)
and similarly, p^2 + 2 = (6k+5)^2 + 2 = 36k^2 + 60k + 27 = 3(12k^2 + 20k + 3)
so both of these are composite so that is great.
But is there a way i can justify that any prime p >= 5 can be written as 6k + 1 or 6k + 5?
I mean i can go through a ton of examples and the remainders are only 1 or 5 but examples don't mean anything.
Can someone help me justify that first step.
I just thought of something can someone tell me if this is correct. for p primes p >=5 we can only get remainders 1 or 5 when dividing by 6 because if we get 2 3 4 we see what happens
6k + 2 = 2(3k +1)
6k + 3 = 3(2k +1)
6k + 4 = 2(2k + 2) and none of these can be prime because they have factors of either 2 or 3.
Is this correct?
Clearly, every prime number greater than 5 can be written in the form 3k+1 or 3k+2. Then all that you need to demonstrate is that (3k+1)2+2 and (3k+2)2+2 are composite. This is similar to your line of thinking.
ah ok, thank you very much
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
