Problem with Second Order Differential Equation
scienceguy288
I am stuck and after several attempts, have made little progress.
Solve: (x'-t)x''-x'=0
I know that the dependent variable x is missing. Therefore, I substitute x'=p and x''=p', giving me, pp'-p't-p=0. However, here I get stuck. If I try to rearrange to give me a Bernoulli form, I get p-(p/p')=t and then get -p'/p+1/p=1/t, which cannot be solved by setting w=y^(1-n) as this would equal 1.
Can anyone give me a push in the right direction from this ( pp'-p't-p=0) point on?
pp' - (p't + p) = 0
The term in brackets is the derivative of something you can recognise? And so is the first term?
epenguin said:
pp' - (p't + p) = 0
Still stumped. I don't recognize that as anything I have seen before as far as I know...
You don't recognise what when differentiated gives you pp'?
Then for the bracketed term, well to give you a product (p't) in it, the thing differentiated probably has to be a product. :wink:
Nope...
I see that [pt]'=p't+p, but I don't see how that can help solve this...
[p*p]'=2*p*p'.
Dick said:
[p*p]'=2*p*p'.
Right, so [(y^2)/2)]'=pp'. I still don't see how that is helpful...Sorry for my thickheadedness, but I am just not seeing it...
pp' - (p't + p)=[p*p/2-pt]'=0. Are SURE you don't see it? Integrate both sides.
Okay, so the left will become p/2(p-2t)+c. The right is the integral of a derivative, so it will become simply (p^2)/2-pt. After simplification this just results in 0=0, though?
Just what sort of 'simplification' are you referring to? p isn't a constant. It's a function.
Well, Integrating both sides will give us
p/2(p-2t)+c=(p^2)/2-pt
(p^2)/2-2tp/2+c=(p^2)/2-pt
((p^2)/2-pt)+c=(p^2)/2-pt
0=0
I meant integrate both sides of [p*p/2-pt]'=0. What are YOU doing?
(p^2)/2-pt=constant?
Yes, now solve for p.
Alright, so we get p=t+/-Sqrt[tc+t^2], integrating that in terms of t to get x=(t (t + Sqrt[2 c + t^2]) + 2 c Log[2 (t + Sqrt[2 c + t^2])])/2 and x=(t (t - Sqrt[2 c + t^2]) - 2 c Log[2 (t + Sqrt[2 c + t^2])])/2
Thanks for helping me, I finally got the right answer. Your advise was truly indispensable!
I'm comming to this late and clearly Mark44 has given you sufficient help. But when I looked at that equation, I saw it as (p- t)p'= p or
\frac{dp}{dt}= \frac{p}{p-t}
Now let y= p- t. Then dy/dt= dp/dt- 1 so that dp/dt= dy/dt+ 1 and p= y+ t. The equation becomes
\frac{dy}{dt}+ 1= \frac{y- t}{y}= 1- \frac{t}{y}
which is separable:
ydy= -tdt
so that y^2= -t^2+ C.
Now, go back to x: y= p- t= x'- t so that the equation is
(x&#039;- t)^2= C- t^2[/itex]<br /> <br /> x&amp;#039;= t\pm\sqrt{C- t^2}
