Problem with this question(lenear algebra)
  • Thread starter Thread starter transgalactic
    Algebra
transgalactic
in A i am asked to find the matrix of T
in B i need to find ker T and I am T
in C i need to find polinomial g(y) so T(y)=y+2
i tried to solve each one and i got problematic points
http://img165.imageshack.us/img165/5331/unt.th.gif
A) Your solution looks correct.
B) You found correctly that Ker(T) consists of vectors of the form (x,0,0,0). This can can be written as Ker(T)=span{(1,0,0,0)}.
Regarding the image of T: Your solution is correct, but one can also find a simpler basis consisting of standard basis vectors.
C) Look at the system of linear equations you extracted from the matrix equation, there is a small error. Also, since T has a one-dimensional kernel there will be infinitely many solutions.
regarding B i get 0*x=0
on what basis i can state that its
(x,0,0,0)
where is the error in C
(x,0,0,0)
Well, you are trying to find all possible values of x,y,z,t so that T((x,y,z,t))=0. You found that this means that 0=x*0, y=0, z=0, t=0. So x can be any number (0=x*0 is true for all x) and y,z,t have to be zero. So the solutions of the equation T((x,y,z,t))=0 are exactly the vectors of the form (x,0,0,0), where x is any number.
The first equation, x+2y=2, should be y+2z=2.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
