Problems with the Dreamliner battery
  • Thread starter Greg Bernhardt
    Battery
187 replies · 44K views · last reply
OmCheeto said:
I quoted someone, to that effect, the other day.
I cannot find my quote, nor who else echoed that...
:cry:
I looked back a bit in your posting history and couldn't find it yet. Do you know which day you did it on?
OmCheeto said:
Ah ha!
Just did the experiment.
Do not try this at home. Although I didn't die, you will...
In trying to understand how such a thing could happen, I tried to figure out the resistance of seawater, as the google answers to my question, used bizarre, unheard of terms:
Anyways, I mixed together a solution of seawater(1 pint of water and 1 tblsp of salt in a pyrex measuring cup), and tried to measure the resistance with my VOM: 1.2kΩ on the 200kΩ scale, and 85kΩ on the 2MΩ scale. Complete nonsense.
So I hooked up my marine battery in series with a 1Ω resistor with my 1 pint of seawater and came up with a value of ≈11Ω.
Photo of a battery test setup on a rusty metal tray: a glass Pyrex measuring cup of yellowish liquid, a red handheld multimeter with probes, a silver bench power supply, and a battery with cables attached.
I decided that the 11Ω value was irrelevant to the problem, as while I watched, Hydrogen and Oxygen gasses were being emitted at a non-insignificant rate. I didn't dilly-dally in deciding that this experiment could have very bad results, as my 6 gallon gasoline tank was tethered to my battery, and less than a foot away. A spark would have resulted in the HHO mixture igniting, potentially igniting any fumes from the gasoline tank.
I disconnected the experiment, in a thoughtful manner, as, an acquaintance of mine, while trying to retrieve his wallet from the dashboard of his burning car, was unfortunate enough to do that, the moment his car burst into flames.
He never looked the same after that. He looked a little better after the plastic surgeons made him a new nose, but not much.
We're going to need to change your username to Danger. Oh wait...
OmCheeto said:
Ah ha!
Photo of a boat's open engine compartment with a battery, a red-handled digital multimeter, and a Pyrex measuring cup of yellowish liquid on the deck, with a grey DC power supply to the right.
Glad you made it back safely!
You are right, 12V + seawater will not burn due directly to the electrical load of the seawater.
What happens is that corrosion (take a look at your contacts that were in the water) can cause low resistance shorts which then can then burn. Their creepage distance requirements probably did not anticipate being submerged.
If it had been any other car, I probably would not have researched this incident. But I knew Fisker used A123's batteries, and they were one of the safest lithium batteries on the market.
GM turns to A123 Systems for batteries less volatile than Chevrolet Volt’s
December 08, 2011
GM is using phosphate-based lithium-ion batteries from Waltham, Massachusetts-based A123 Systems Inc. that are less likely to burn than other lithium chemistry, including that used in the Volt model that went on sale last year, according to the companies. ...
It should be noted that I still haven't sold my A123Q, aka B456, stocks. I foolishly assumed that trading of the stocks would cease once the company went bankrupt. Unfortunately, I was so disgusted with the whole incident, I paid no attention to my portfolio, which was set to auto-purchase shares each month, and only discovered later that I had doubled the number of shares I owned in just a few months. If I hadn't shut that down, it would have doubled again by now.
Oh dear... I see I now own another Q suffixed stock! XIDEQ... :cry:
I guess the battery market is as brutal as the solar panel market.
ps. The battery that I did my seawater test with is an Exide.
Another dreamliner electrical screw-up. Engine fire extinguishers wired the wrong way round on three aircraft in service.
http://www.bloomberg.com/news/2013-...-in-dreamliners-as-jal-plane-scraps-trip.html
That wouldn't be funny if there was a problem that caused an engine fire. The engine fire extinguishers will put out most things, but they are pretty much a one-off last resort. Discharge a fire bottle into the one engine still working, and you had better be qualified as a glider pilot.
don't feel bad I still have Enron.
http://newscenter.lbl.gov/wp-content/uploads/Balsara-dendrite-growth.jpg
Here we go again. Dendrites grow slowly over time like fractures.
Researchers with the U.S. Department of Energy (DOE)’s Lawrence Berkeley National Laboratory (Berkeley Lab) have discovered that during the early stages of development, the bulk of dendrite material lies below the surface of the lithium electrode, underneath the electrode/electrolyte interface. Using X-ray microtomography at Berkeley Lab’s Advanced Light Source (ALS), a team led by Nitash Balsara, a faculty scientist with Berkeley Lab’s Materials Sciences Division, observed the seeds of dendrites forming in lithium anodes and growing out into a polymer electrolyte during cycling. It was not until the advanced stages of development that the bulk of dendrite material was in the electrolyte.
http://newscenter.lbl.gov/science-shorts/2013/12/17/roots-of-the-lithium-battery/
Dreamliner Grounded As White Smoke Spotted -- TODAY!
http://news.sky.com/story/1195209/dreamliner-grounded-as-white-smoke-spotted
Another Telsa crash and fire but this one has a 'twist'.
http://ktla.com/2014/07/04/tesla-cr...lits-in-half-in-weho-multiple-people-injured/
Night news still of a burning crashed car on a city street, flames and smoke rising from the wreck, with a police vehicle and yellow tape in the foreground.
You can see flaming parts of the broken battery pack ejecting flaming cells like missiles but the car looks to be incredibly safe if you are free of the resulting fire.
The first part gives a good view of the scale of the wreck. It looks like the driver was trying to turn or slid at high speed after hitting the Honda and hit the pole near the middle of the car spilling most of the battery in the street. Losing that heavy battery might have saved his life.
https://www.youtube.com/watch?v=kE_u731EmYA
Not driving any stolen car at 100 mph down the streets of LA, and not self T-boning a light pole, will probably also save your life. (I read that he actually took out two light poles.)
Latest reports say the the thief is still alive, though one of the people he injured is still in critical condition.
I consider this a non-issue.
If the battery falls out of the car in a side-on collision, I think that's a major design issue in its own right, independent of any pyrotechnic side effects.
The car hit the pole with enough force to slice the car in two. Looking at the layout of the battery, and knowing there are over 7000 individual cells that make up the battery, I'm guessing the "battery" did not fall out of the car.
The gas tank on my truck is about 5 feet long and is positioned centrally, running parallel to the drive shaft. Would that also be considered a major design issue if 17 gallons of gasoline were released in a similar accident? Both the Tesla and my Truck have 5 star crash ratings.
On the following website, they claim:
Pole Side Impact
In the test, the car tested is propelled sideways at 29kph (18mph) into a rigid pole.
I can go faster than that on a bicycle.
How much would it add to the cost of vehicles if the speed of the test was increased to 100kph (62mph)? Do we really need to engineer vehicles to keep people alive, based on the driving habits of contenders for the Darwin Award?
Consensus at the Oregon Electric Vehicle Assn about this incident? : Yawn
OK, if you think that was the root cause, then that's still a major design issue.
Crash test regulations may or may not be a marketing exercise, but if the car hit a standard item of highway engineering (I'm not familiar with what the US term "pole" signifies here) while being propelled by its own engine, that event is going to happen sooner or later.
I'll be interested to see the first head-on crash between two Teslas with a closing speed of around 200 mph...
They're mainly right. A ICE car could have turned into spinning firebomb also in those conditions. My main point with the post was to demonstrate the reaction of some types of lithium batteries is very similar to carbon based fuels in these extreme conditions with the added punch of not being able to use normal extinguishers like water or water based products to control the fires. The firefighters just letting it burnout was the safest approach. With an isolate car in the street that's a good option if no one is trapped inside, in a flying plane filled with people it's not.
Don't do this
https://www.youtube.com/watch?v=ojGaAGDVsCc
(We have class D bottles at work for hydride metal fires, nasty stuff but we don't have to use the Lithium approved types)
http://www.safetyemporium.com/ILPI_Site/WebPagesUS/detail.htm&&2eiBpe0obDuox2NvxMpoLGxolobo2bbBeJ1gctPw1JaImsaa2r1GcDQUR4Vh_S6alkWaTWuala?09584
First, decide what crash tests are supposed to be testing for.
For example, the US crash tests for fenders/bumpers are impacts with a rigid barrier at 3mph and 6mph, designed to measure the damage to the car.
The corresponding EU test is impact with a deformable object at 25mph, designed to measure the damage to the object - e.g. a pedestrian.
AlephZero said:
... (I'm not familiar with what the US term "pole" signifies here) ...
Odd, as I quoted a european website, regarding the "pole" test.
About us
Established in 1997, Euro NCAP is composed of seven European Governments as well as motoring and consumer organisations in every European country. (Read more on our members)
That would be fun to watch. Darwinians are quite entertaining, regardless of their energy source.
Just when you thought it was over... To keep a Boeing Dreamliner flying, reboot once every 248 days. What the heck did they do - give it a Windows operating system? :eek:
According to the FAA, there's a software bug in the 787 Dreamliner that can cause its electrical system to fail and, as a result, lead to "loss of control" of the plane. But why? The FAA says this is triggered by the aircraft's electrical generators, which could give out if they have been powered on continuously for over eight months.
One of my solid state drives had nearly exactly the same problem. After a certain number of run hours -- something like 248 days -- it turned-into a a brick. Fortunately, it had a reset routine and bios flash to fix it.
Now with the dreamliner it says "continuously powered", so I suppose you could just reboot it once every 8 months to work-around this bug.
Have none of the programmers heard of signed integer overflow bugs? At 100hz 248.5 days would be just about right. One woodpecker!
Re: Newest Dreamliner Bug.
Once again, this proves that all the kings horses and all the kings men can never make flawless yet complex software. There is no such thing and there never will be.
I'm afraid that the airline industry will be doomed to follow the nuclear industry. During Y2K remediation reviews, we found software written in the early 1960s still in use, and still being replicated from the oldest plants into the newest ones. The source code, who wrote it, what its function was, and how it works are all unknown, but nobody dared to touch it. You see, when software is in operation for 50 years without failure it attains the status of "proven". No matter how many latent bugs remain in the proven software, we are pretty sure that they will never be triggered or cause a problem. Anything new, regarless of the time and money spent to perfect it, is "unproven."
Therefore, I predict, that after 10 or so years pass without new Dreamliner bugs causing failures, that nobody will ever dare touch it thereafter. Even if a previously unknown bug causes a crash 25 years from now, the risk of any remediation will be greater than the risk of doing nothing.
Agreed.
Not sure about never touching it. Look at the Linux kernel. It could very likely be one of the most complex software codes out there. But bugs are still getting regularly fixed. And Linux kernels get eventually used in many fairly critical tasks.
So I guess although we can never certify complex code as "bug free" that doesn't stop us from carefully fixing bugs.
Diminishing returns is a natural law .
On the other hand, it remains to be seen what will be the effect of this structure imposed by the machines on human language and thought.
I was the last of the "Slide Rule Generation" and well remember when Miami had only one TV station that was on only afternoon and evenings.
I've seen the "Sesame Street Generation" come to power in society.
Check out code.org and try their "hour of code" exercise - it's made for little kids but it's an absolute blast.
I wish i could live long enough to see what these computer generation kids do.
old jim
oops- that was a hijack, wasn't it ?
They should fix that integer overflow.
and make sure it's a global variable.
Reverse of the Great Seal of the United States: an eye above a pyramid of thirteen courses, with MDCCLXXVI below, flanked by the mottoes ANNUIT COEPTIS and NOVUS ORDO SECLORUM on a ring.
That's a different scenario. If Linux was used for a critical task, and if it had not been touched for 10 years, and if nobody today had experience changing Linux in the past 10 years, would you change it then?
The Linux kernel gets already used for critical tasks. Well, depends on what your definition of critical is. Not where Real Time OSs are needed but Critical tasks nevertheless.
The "not touched for 10 years" point I agree with you. But will codes like the aircraft software go untouched & unmaintained for 10 years? Is the source really as ill-documented as you mention for nuclear industry codes?
Software engineering in the 1960's was a totally different beast than when the Dreamliner codes got written.
Good points. Time will tell.
But eventually, someone will notice that most Dreamliner bugs found in service result from the most recent software changes, and that someone will blow the whistle. Think of incidents such as the recent nationwide outage at Starbucks. Consider the risk-benefit ratio if auto manufacturers broadcast updates to all those embedded microcontrollers in cars. When things run well, there are strong incentives to leave them alone.
I would be interested to hear how many embedded Linux apps run with the software initially installed (perhaps burned in ROM) and never updated. I have a GPS chartplotter on my vessel that fits that description. It's function is pretty critical.
I think purely aesthetic patches will be frowned upon. Or patches that add marginal functionality. But what about known bugs & the resultant bug fixes? Often a bug fix can trigger an unintended, unanticipated disaster.
What's the empirical observation, though? Are most inconvenient / massive bug-related-down-times the result of proximal updates?
Given the combinatorically large number of states a complex software can be, isn't it about as likely that a bug latent since inception gets accidentally triggered at some later time just by pure chance leading to disastrous consequences? Without being the result of any new updates really.
Ergo, is ROMing critical software & never updating it a better option in practice?
rollingstein said:
Stole this from a comment elsewhere but sounds most plausible:
"248 days == 2^31 100ths of a second. even in 2015, our airplanes have integer overflow bugs "
A few things to consider about aircraft control computers.
There are independently reset-able paths usually using dissimilar hardware. Resetting a CPU or event an entire board will barely effect system operation.
Most electrical systems on a modern airplane reset once or twice a flight due to single event upsets (SEUs).
