Product Detector: Learn When to Use & Benefits
  • Thread starter Thread starter onceinalifetim
    Detector Product
A product detector is primarily used in single sideband receivers to mix an amplified input signal with a local oscillator, which corresponds to the missing carrier of the sideband signal. Unlike envelope detectors, product detectors are more expensive but provide better performance in terms of signal fidelity. They require filtering to eliminate the carrier from the audio output, with advanced designs employing balanced techniques to cancel it out. There is no loss of power when using a product detector, as the carrier is considered an unwanted output that can harm audio amplification. Understanding these aspects is crucial for determining when to use a product detector effectively.
onceinalifetim
Hello
I am trying to learn something and really hope to get some help..
i know the use of envelope detector.. but when to use product detector?
i know product detector will be more expensive than envelope detector.. please help
onceinalifetim said:
Hello
Huh ? What are you talking about?
hello.
what is the condition to use product detector?
hello.
OK, I googled the term and now I understand your question, but I don't know the answer.
how the overall power becomes lesser when one side band is taken away by the bandpass filter and also how it limits the bandwidth of the signal
A product detector is just a mixer where the two input signals are close together in frequency and the output, which is the difference between the two input frequencies, is generally an audio signal.
They are used in single sideband receivers to mix an amplified input signal with a local oscillator whose frequency corresponds with the missing carrier of the sideband signal.
Simple product detectors require filtering to remove the carrier from the audio output signal, but better ones use balanced techniques to cancel it out.
There is no loss of power involved in doing this as the carrier is an unwanted and harmful output if it gets to the audio amplifier.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
