Projectile Angle: Finding the Launch Angle
  • Thread starter Thread starter airforce840
    Angle Projectile
The discussion focuses on deriving the launch angle for a projectile launched from an initial height with a given speed, aiming to hit a target at a different height and position. The proper launch angle is expressed using a formula involving the target's position and height differences. Participants clarify the need to separate the initial velocity into x and y components to solve for time and angle. They emphasize eliminating time from the equations to arrive at a quadratic equation for the tangent of the angle. The conversation highlights the mathematical approach to solving projectile motion problems while ignoring air resistance.
airforce840
Suppose that a projectile is launched from an initial height yi with an initial speed Vi and it strikes a target at a fianl height yf and fianl position xf. Show that the proper launch angle (feta symbol) is given by
feta = tan^-1 [xf +/- Square root of Xf^2 - 4k(k-Delta y) / 2K]
where K = ayXf^2/ 2 Vi^2
sry for the HORRIBLE typing of formulas..i don't know how to add them in.
and i don't have a photocopier.
thanks in advanced for any help on this one.
Patrick
I'm assuming that air resistance is not being taken into account here.
So, initial velocity can be split into x and y components, from that, the position as a function of time can be obtained, and then solve for the angle.
(A is the angle of projection)
x-component:
<br /> v_x = v_0cosA<br />
y-component:
<br /> v_y = v_0sinA<br />
Therefore, the postions are:
<br /> s_x = v_0tcosA<br /> s_y = v_0tsinA - \frac{gt^2}{2}<br />
Then re-arrange the first one of these for t, then substitute into the second equation, and solve for A (you should get a quadratic in tanA). You will need to take into account the initial height at the time of projection, but it should work. By the way, sorry about the dodge formulas, I'm not very good at using them, suppose that its lack of practise...
uh... is there sumthing else that means S because I've never seen Sx before.. lol
other than that i kinda understand and yes..windresistance is always ignored in our class.. i don't know why but our teacher will not go into it
i figured out most of it.. but i confused my self on this because there's 2 ways to do it. the 1st equation to t and then sx.. and u get this
t= -vi sin(feta) +- Square root of vi sin (feta) - 4(-sy) / 2
and if i use the other one.. its more complicated i think sx= vi(-vi Sin(feta)+-square root of (vi Sin (feta) - (4)(/-sy) / 2) cos (feta)
how do i solve for feta with EITHER of these horribly confusing mess' and if someone can tell me how to write these equations with those images..lol that would be nice..cuz i think it makes it look worse.
thanks in advanced
Patrick
Read carefully what finchie_88 said. He has said every thing you need to do to get tan (A) or launch angle.
There is one way to solve this and there are two equations with two unknowns namely tan A and time 't'. You need to eliminate t first. In order to do that, find 't' from the first equation.
X_f = v_i cos(A) t
and substitute this one in the second equation.
\Delta y = -v_i sin(A) t + \frac{gt^2}{2}
Do some re-arranging and you will end up with the following quadratic equation,
\frac{g X_f ^2}{2v_i ^2} tan^2 A - X_f tan A + (\frac{g X_f ^2}{2v_i ^2} - \Delta y) = 0
i.e.
K tan^2 A - X_f tan A + (K - \Delta y) = 0
I am sure you can solve this.
Basically what we have done is using s = ut + 1/2 g t^2 horizontally and vertically to the given problem and the rest of it is just mathematics.
Hope this helps.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
